Alex's 75 gallon mostly automated tank
PostPosted: Mon Sep 17, 2012 8:02 pm
So I've been with you guys for a while and never posted my builds. I will document here and share code that might be helpful to all of you!
I will place my custom code as I develop it to hopefully help others in their automation and customization efforts.
Webcam Feed:
Setup/Equipment:
RA+ w/ expansions: 2nd relay, salinity, RF, dosers
Tank: Leemar Glass 75 gallon 36"x24"x20"
Sump: 20 gallon long
Refugium: Large Aquafuge
Lighting: 2x Ecotech Radions
Protein Skimmer: ASM G3
Circulation: MP 40
Return: Eheim 1262
Other equipment: BRS Dual Chamber (Carbon & GFO) Reactor, BRS Bio Pellets, RA Dosing
Banners:
New setup tank:
Other stats:
WL: status/chart.aspx?id=alexwbush&filter=WL
Coding Plan:
Custom screen in progress
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  /* Drawing this:
   01/01/12 00:00:00 AM
   Disp 79.9  pH     8.00
   Sump 79.9  Sal    0.60
   Room 77.7  WtrLvl Ok
   1 2 3 4 5 6 7 8
   1 2 3 4 5 6 7 8
   Moon Waning Crescent
   Intensity 88%
   Sunrise   06:15
   Sunset    18:12
  /* Colors used in this script:
     DefaultFGColor   - For basic font and line
     DefaultBGColor   - For background color
     PHColor          - For values that may change
     OutletOnBGColor  - For okay water level
     OutletOffBGColor - For low water level
     To change colors, modify these values in ReefAngel_CustomColors.h file
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.Clear(DefaultFGColor, 1, 11, 128, 11);
  //ReefAngel.LCD.DrawText(fcolor,bcolor,x,y,"text");
  //Line 1 - Display Temp & pH
  x = 8;
  y = 15;
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Disp");
  x += 30;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], PHColor, x, y, 10);
  x = 70;
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"pH");
  x += 30;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x, y, 100);
  //Line 2 - Sump & Salinity
  x = 8;
  y += 10;
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Sump");
  x += 30;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], PHColor, x, y, 10);
  x = 70;
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Sal");
  x += 30;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Salinity, PHColor, x, y, 10);
  //Line 3 - Room
  x = 8;
  y += 10;
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Room");
  x += 30;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], PHColor, x, y, 10);
  x = 70;
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Lvl");
  x += 30;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(), PHColor, x, y, 1);
  //Lines 4 and 5 - Relays
  x = 12;
  y += 15;
  // draw main relay
  //Line 3 - Room
  x = 8;
  y += 20;
  x += 30;
  ReefAngel.LCD.DrawSingleMonitor(InternalMemory.read(258), PHColor, x, y, 1);
  x = 70;
  ReefAngel.LCD.DrawSingleMonitor(InternalMemory.read(259), PHColor, x, y, 1);
  x += 30;
  ReefAngel.LCD.DrawSingleMonitor(topofflevel, PHColor, x, y, 1);
Radion w/moon cycle and variable day periods in progress
First, paste these variables in the area marked "Place global variable code below/above here"
byte starthr = 8; //start hour for radion cycle (0-23)
byte startmin = 0; //start minute for radion cycle (0-59)
byte endhr = 22; //end hour for radion cycle (0-23)
byte endmin = 0; //end min for radion cycle (0-59)
byte intensity = 80; //intensity of radion cycle (0-100)
Then paste the following in main code:
  /* Radion custom curve
    For testing:
    ReefAngel.RF.SetChannel( Radion_White, PWMParabola(10,0,21,0,0,75,0) );
    ReefAngel.RF.SetChannel( Radion_RoyalBlue, PWMParabola(8,0,22,0,0,100,0) );
    ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(11,30,21,0,0,20,0) );
    ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(12,0,19,0,0,30,0) );
    ReefAngel.RF.SetChannel( Radion_Blue, PWMParabola(9,0,21,0,0,45,0) );
    ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(8,0,22,0,0,100,0) );
    ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
    ReefAngel.RF.SetChannel( Radion_White, PWMParabola(starthr+2,startmin,endhr-1,endmin,0,intensity*.75,0) );
    ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(starthr+3,startmin+30,endhr-1,endmin,0,intensity*.2,0) );
    ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(starthr+4,startmin,endhr-3,endmin,0,intensity*.3,0) );
    ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(starthr,startmin,endhr,endhr,0,intensity,0) );
    /* Radion moon cycle
      Currently controls RoyalBlue.  If normal daylight, run defined parabola based on start and end radion cycle parameters (aka day cycle).  If after hours, run moonlight.
    if ( (hour() < starthr && (minute() < startmin || startmin == 0) ) || (hour() > endhr && minute() > endmin) ) // If time time is before or after normal daylight cycle
      ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() ); // Run moonphase on RoyalBlue
    else // Or else...
      ReefAngel.RF.SetChannel( Radion_RoyalBlue, PWMParabola(starthr,startmin,endhr,endmin,0,intensity,0) ); // Run day cycle parabola
      ReefAngel.Relay.On(Port4); // And turn on the Vortech
    if ( second()==0 ) ReefAngel.RF.RadionWrite();
Auto water change pending
Automated feeding complete
  /* Auto feeding mode starts.
   Feeder set for 17:30, start feeding mode at 17:25. */
  if ( hour() == 17 && minute() == 25 && second() ==0 ) //if time is 17:25:00
    ReefAngel.FeedingModeStart(); //start feeding mode
PostPosted: Mon Sep 17, 2012 8:27 pm
Second post will be my full current code.
Updated 3/2/15
#include <WiFiAlert.h>
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.LightsOnPorts = Port2Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.DelayedOn( Box1_Port5 ); //turn on skimmer 10 min delay
    ReefAngel.Relay.On( Box2_Port1 ); //turn on Auto Feeding
    ReefAngel.MoonLights( Port2 );        //Turns on 20:00, off at 09:30
    ReefAngel.WaterLevelATO( Port4 );
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port8 ) );
//    ReefAngel.PWM.SetDaylight( MoonPhase() );
//    ReefAngel.PWM.SetActinic( MoonPhase() );
    RunRadion();       //Runs Radion
    DailyFeed();       //Automatic fish feeding
    NightMode();       //Runs Night mode
    AutoWaterChange();  //Runs Auto water change
    DailyReport();     //Sends Daily Reports
    ReefAngel.Portal( "alexwbush" );
void NightMode(){
  // Turn on Night Mode if Fuge light is on (Fuge comes on at night)
    if (ReefAngel.Relay.Status( Port2 )== 1 && ReefAngel.RF.Mode!=Night)
      //ReefAngel.RF.UseMemory=false;
      ReefAngel.RF.SetMode(Night,20,0);
      ReefAngel.RF.SetMode(Night_Stop,0,0);
      //ReefAngel.RF.UseMemory=true;
void DailyFeed(){
     Feeder set for 12:00, start feeding mode at 11:55. */
    if (ReefAngel.Relay.Status(Box2_Port1)==1)
      if ( hour() == 11 && minute() == 55 && second() ==0 ) //if time is 11:55:00
void DailyReport() {
   static WiFiAlert dailyReport;
   char msg[32];
   char temp[10];
   char ph[10];
   if ((now()+(9*SECS_PER_HOUR))%(12*SECS_PER_HOUR)==0) {
     dtostrf((float)ReefAngel.Params.Temp[T1_PROBE]/10,3, 1, temp);
     dtostrf((float)ReefAngel.Params.PH/100,4, 2, ph);
     sprintf(msg,"Daily Report: Temp:+%s+PH:+%s+WL:+%d",temp,ph,ReefAngel.WaterLevel.GetLevel());
     dailyReport.Send(msg);
     sprintf(msg,"Temp:+%s+PH:+%s+WL:+%d",temp,ph,ReefAngel.WaterLevel.GetLevel());
void RunRadion()
  //ReefAngel.RF.SetChannel
  //ReefAngel.RF.UseMemory = true;
  if(ReefAngel.Relay.Status(Box2_Port6)==1 || ReefAngel.Relay.Status(Box2_Port7)==1 || ReefAngel.Relay.Status(Box2_Port8)==1)
    ConstantRadion();        //Runs radions on constant level (for overrides)
  else if( ReefAngel.Relay.Status(Port2)== 1 ) //Try this: hour() == 11 && minute() == 55 && second() ==0
    RadionNight();      //Runs Radion in night mode
  else{
    ReefAngel.RF.ChannelWhiteSlope();
    ReefAngel.RF.ChannelRoyalBlueSlope();
    ReefAngel.RF.ChannelRedSlope();
    ReefAngel.RF.ChannelGreenSlope();
    ReefAngel.RF.ChannelBlueSlope();
    ReefAngel.RF.ChannelIntensitySlope();
void RadionNight() {
    ReefAngel.RF.SetChannel( Radion_White, 0 );
    ReefAngel.RF.SetChannel( Radion_RoyalBlue, 100 );
    ReefAngel.RF.SetChannel( Radion_Red, 0 );
    ReefAngel.RF.SetChannel( Radion_Green, 0 );
    ReefAngel.RF.SetChannel( Radion_Blue, 0 );
    ReefAngel.RF.SetChannel( Radion_Intensity, MoonPhase() );
void ConstantRadion() {
    byte white=InternalMemory.RadionSlopeEndW_read();
    byte royal_blue=InternalMemory.RadionSlopeEndRB_read();
    byte red=InternalMemory.RadionSlopeEndR_read();
    byte green=InternalMemory.RadionSlopeEndG_read();
    byte blue=InternalMemory.RadionSlopeEndB_read();
    byte intensity=InternalMemory.RadionSlopeEndI_read();
    static time_t t;
    int runtime=180;
    if(ReefAngel.Relay.Status(Box2_Port8)==1) //Movie mode
      if(ReefAngel.Relay.isMaskOn(Box2_Port8))
        t=now();
      if(now()-t < runtime){
        intensity=0;
        ReefAngel.Relay.Override(Box1_Port6, 0); //refugium light off
      else ReefAngel.Relay.Override(Box2_Port8,2);
       ReefAngel.Relay.Override(Box1_Port6, 2); //refugium light auto
       if(ReefAngel.Relay.Status(Box2_Port7)==1) //Actinic
          white=0;
          blue=0;
          royal_blue=0;
          green=0;
          red=0;
          intensity=75;
    ReefAngel.RF.SetChannel( Radion_White, white );
    ReefAngel.RF.SetChannel( Radion_RoyalBlue, royal_blue );
    ReefAngel.RF.SetChannel( Radion_Red, red );
    ReefAngel.RF.SetChannel( Radion_Green, green );
    ReefAngel.RF.SetChannel( Radion_Blue, blue );
    ReefAngel.RF.SetChannel( Radion_Intensity, intensity );
    10k:
          white=100;
          blue=75;
          royal_blue=75;
          green=100;
          red=100;
          intensity=75;
    14k:
          white=75;
          blue=100;
          royal_blue=100;
          green=75;
          red=75;
          intensity=75;
    20k:
          white=37;
          blue=100;
          royal_blue=100;
          green=17;
          red=37;
          intensity=75;
void AutoWaterChange(){
    /* Automatic water change
    Trigger by Box2_Port3 (fake relay) that can be triggered by portal or RA app. Will turn on waste pump in sump is water
    level is above low sump level (memory location 340) or if waste bucket is full. Then will turn off waste pump and turn on
    fresh water pump to pump in water until sump water level is returned to normal. Meanwhile, return, skimmer, and heater
    should continue to operate normally.
    Utilized ports:
     Port 4       ATO: toggled off in auto water change
     Box1_Port5   Skimmer: will not exit mode unless skimmer is on (to account for lower water level when on)
     Box1_Port6   Sump light: toggled on in auto water change
     Box1_Port7   Waste water pump: Maxijet 1200 located in sump with drain hose to waste bucket
     Box1_Port8   Fresh water pump:
     Box2_Port3   Auto Water Change trigger: fake relay box used for setting various "modes"
    Variables:
     WaterLevel.GetLevel(0)    Water level sensor in pump: Returns a value 0-100+
     HighATO.IsActive()        Float switch on waste bucket: Returns a value to indicate whether float switch is on bottom or floating
    Memory locations:
     Location 331   (ATO Level Low Value set @ 62)
     Location 332   (ATO Level High Value) (NOT UTILIZED, but could be helpful for changes)
     Location 340   (Water Level 1 Min Value -> Used for low water level in sump... set @ 25)
    byte topofflevel=InternalMemory.read(332);
    byte sumplowlevel=InternalMemory.read(340);
    if (ReefAngel.Relay.Status(Box2_Port3)==1)
      ReefAngel.Relay.Override(Box1_Port6, 1); //turn on sump light
      ReefAngel.Relay.Override(Port4, 0); //turn off ATO
      /* Drain waste water from sump if:
         1. Water level is above the low sump level (Location 340/"Water Level 1 Min Value")
         2. AND the ATO high level is not met (waste bucket NOT full)
         3. AND water fill is not on */
      if (ReefAngel.WaterLevel.GetLevel(0) > sumplowlevel && ReefAngel.HighATO.IsActive() && ReefAngel.Relay.Status(Box1_Port8)==0)
        ReefAngel.Relay.On(Box1_Port7); //turn on drain/waste pump
      else ReefAngel.Relay.Off(Box1_Port7); //turn off drain/waste pump
      /* End waste water */
      /* Fill with fresh salt water if:
         1. Water level is below normal high level of autotop off (Location 332/"ATO Level High Value")
         2. AND waste pump is not on
         3. AND skimmer is on (to account for water level difference) */
      if (ReefAngel.WaterLevel.GetLevel(0) < topofflevel && ReefAngel.Relay.Status(Box1_Port7)==0 && ReefAngel.Relay.Status(Box1_Port5)==1)
        ReefAngel.Relay.On(Box1_Port8); //turn on drain/waste pump
      else ReefAngel.Relay.Off(Box1_Port8); //turn off fresh saltwater pump
      /* End clean water fill */
      /* Exit auto water change (make Box2_Port3 auto) if:
         1. Waste pump is off
         2. AND fresh water pump is off */
      if (ReefAngel.Relay.Status(Box1_Port7)==0 && ReefAngel.Relay.Status(Box1_Port8)==0)
        ReefAngel.Relay.Override(Box2_Port3, 2); //auto water change back to auto
      ReefAngel.Relay.Override(Box1_Port6, 2); //auto sump light
      ReefAngel.Relay.Override(Port4, 2); //auto ATO
void HoldingCode(){
    /* Override for skimmer cleaning */
/*    static unsigned long SkimmerTimer;
    if (ReefAngel.Relay.Status(Box2_Port2)==1) SkimmerTimer=now();
    if(now()-SkimmerTimer>0 && now()-SkimmerTimer<600) //600s = 10min
      ReefAngel.Relay.Override(Box1_Port5, 0); //turn off skimmer
      ReefAngel.Relay.Override(Box2_Port2, 2);
      ReefAngel.Relay.Override(Box1_Port5, 2); //turn off skimmer
      ReefAngel.Relay.Override(Box1_Port6, 2); //turn on sump light
//      ReefAngel.Relay.Off(Box1_Port6); //turn off sump light
    //180 - 3 min (for test)
    //1800 sec = 30 min
    //3600 sec = 60 min
/*    if(now()-AutoWaterChange>0 && now()-AutoWaterChange<180 && ReefAngel.WaterLevel.GetLevel(0) >0 && ReefAngel.HighATO.IsActive())
//      ReefAngel.Relay.Override(Port3,0); //turn off heater
//      ReefAngel.Relay.Override(Port4,0); //turn off ATO
//      ReefAngel.Relay.Override(Box1_Port5,0); //turn off skimmer
      ReefAngel.Relay.Override(Box1_Port6,1); //turn on sump light
      ReefAngel.Relay.Override(Box1_Port7,1); //turn on waste pump, pump water out
      ReefAngel.Relay.Override(Box1_Port6,2); //turn on sump light
      ReefAngel.Relay.Override(Box1_Port7,2); //turn on waste pump, pump water out
/*    else if (now()-AutoWaterChange>180 && ReefAngel.WaterLevel.GetLevel(0) < 100)
      ReefAngel.Relay.Override(Box1_Port7,2); //turn off waste pump, pump water out
      ReefAngel.Relay.Override(Box1_Port8,1); //turn on fresh saltwater, pump water in
      ReefAngel.Relay.Override(Port3,2); //return heater to auto
      ReefAngel.Relay.Override(Port4,2); //return ATO to auto
      ReefAngel.Relay.Override(Box1_Port6,2);  //turn off sump light
      ReefAngel.Relay.Override(Box1_Port8,2);  //turn off fresh saltwater, pump water in
      ReefAngel.Relay.Override(Box1_Port3,2);  //turn off Auto Water Change mode
    /* Override test port
    static unsigned long AutoWaterChange;
    if (ReefAngel.Relay.isMaskOn(Box2_Port3)) AutoWaterChange=now();*/
    /* Vortech nutrient transport mode (after feeding mode)
       Turn off nutrient transport mode */
    static unsigned long FeedTime;
    if (ReefAngel.DisplayedMenu==FEEDING_MODE) FeedTime=now();
    if (now()-FeedTime>0 && now()-FeedTime<3600)
      ReefAngel.RF.SetMode(Smart_NTM,155,5);
    /* Vortech night mode
     Info: you can do ReefAngel.Relay.Status(Port2); which will return 0 (off) or 1 (on)
     In this case, my Port 2 is the refurium light. If the refugium light is on, I want
     night mode on the Vortechs on, else off
    // Turn off Night Mode
    if (ReefAngel.Relay.Status( Port2 )== 0 && ReefAngel.RF.Mode==Night)
PostPosted: Tue Sep 18, 2012 2:34 am
Really well done! How do you find the moon cycle with the radion?
Do you know if using that long the royal blue would short the leds life?
Thanks for sharing.
Slow down to speed up
PostPosted: Tue Sep 18, 2012 10:25 am
alexwbush wrote:Unfortunately they don't make a glass roomba yet, so I am still involved there.
Not sure if they are available yet, but close!
http://robosnail.com/about.html
PostPosted: Tue Sep 18, 2012 12:40 pm
pilonstar wrote:Really well done! How do you find the moon cycle with the radion?
Thanks for sharing.
MoonPhase is part of the libraries...
His code has the following check to turn on the moonlights at the right time with:
    else // Or else...
PostPosted: Tue Sep 18, 2012 5:01 pm
I don't think it would shorten the LED life enough to matter when you're probably going to dump or replace the light in 10-15 years max.
I have to test the moonlights, but I think it should run perfectly. Next task on that project is to work with the lat and long code lnevo is working on. I am trying to make it as easy as possible so new people can just copy and paste the code they want instead of hunting through mine to find it. I am a little stuck right now unfortunately since I cannot test without my RA+ board. The RF expansion takes up too much room to run with my regular RA board and the RA+ is 6 hours north. Looks like progress may slow until end of October.
But to add to the challenge... I am leave my tank for 5 whole weeks with no regular supervision. Yup, remember when I said I wanted to automate... this is part of why. I will be 2-3 hrs north, but will monitor with webcam, android app, and RA portal. Hardest part of this process... I don't have a 25 gallon RO top off container. I am considering daisy chaining 5-6 5 gallon buckets into siphoning water to the primary top off container when low. And that's not even technology! Just siphons.
PostPosted: Tue Sep 18, 2012 7:30 pm
hahahahhaha! That thing is $300. I think for that I could hire a maid for years just to clean the glass.
PostPosted: Tue Sep 18, 2012 7:35 pm
Just think how clean that webcam view would be for that remote tank ;)
I was a big automation junkie awhile back in doing home theater, lighting, IR, etc. I tried playing with x10 initially and then I found RA... All downhill from there :)
PostPosted: Tue Sep 18, 2012 11:09 pm
yeah, my dad used to work for a home automation company and I knew tons about home automation including x10. I still have a bunch of those lying around the house.
if-then-else statements can solve the world's problems haha
PostPosted: Wed Sep 19, 2012 9:27 pm
They are totally missing the mark with these. I always thought it would be really cool to have the functionality to "drive" a webcam around the tank to look at whatever I wanted. It's all possible, even with the arduino system, I just don't have the electronic chops to build it myself. :ugeek: Looks like they figured out the hard parts just need to hook on a camera.
Maybe that could be a future add-on to the RA. :D
-Jon
Next
Return to You and your tank
