basic code but not working right?
Posted: Fri Sep 21, 2012 3:17 pm
by mineman@mac.com
Seems that somehow my lights are tied to one of the wavemaker ports. When the main lights are supposed to be off they turn on with one of the wavemaker power heads. The code is very basic (generated by wizard) and to the best of my knowledge I cant figure out why this is happening. Any ideas?
    ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port3Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.SingleATO( false,Port1,2000,0 );
    ReefAngel.Relay.DelayedOn( Port2,10 );
    ReefAngel.StandardLights( Port3,13,30,20,30 );
    ReefAngel.WavemakerRandom( Port5,20,40 );
    ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
    ReefAngel.StandardHeater( Port8,791,800 );
    ReefAngel.Portal( "mineman@mac.com" );
Re: basic code but not working right?
Posted: Fri Sep 21, 2012 7:49 pm
Does it happen all the time??
So, is your lights turning on/off every 20-40 seconds?
Posted: Fri Sep 21, 2012 8:47 pm
by mineman@mac.com
has for the last two nights despite reloading my code a few times.
Thats correct, every 20-40 seconds.
Posted: Fri Sep 21, 2012 9:45 pm
Seems like your cable got shorted out somehow.
Do you have it mounted where it moves all the time?
Posted: Sat Sep 22, 2012 8:14 am
by mineman@mac.com
No movement at all. I have tried wiggling the cable to see if that changes anything but still the same situation.
Posted: Sat Sep 22, 2012 8:24 am
What happens when you swap the ends of the svga cable?
Posted: Sat Sep 22, 2012 9:18 am
by mineman@mac.com
I swapped ends on the cable and same thing.
Posted: Sat Sep 22, 2012 9:42 am
Can you try the ControllerTester code?
Then scroll through each port and see if they also turn together.
File->Sketchbook->Example Codes->ControllerTester
Posted: Sat Sep 22, 2012 9:56 am
by mineman@mac.com
ran the ControllerTester code and they turn on together during testing.
Posted: Sat Sep 22, 2012 9:57 am
Yes, you definitely got something shorted in there.
PM me for RMA
