Outlet cycling
Posted: Fri Sep 28, 2012 8:57 am
by grafspee1217
Hi Roberto,
I was acclimating some corals today and noticed that one of the outlets on the #1 box cycles off every ten minutes or so. It stays off for a few minutes then turns back on. It's outlet #7 on box-1. Can you take a look at the file and see if you notice what is causing it?
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
// The T3 probe is tank temperature and overheat functions
// Overheat temperature setting
// Ports that are always on Pump-8 Wavemakers-5&6
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,751,761 );
ReefAngel.StandardATO( Port2,390 );
ReefAngel.StandardLights( Port3,21,0,9,0 );
//ReefAngel.Wavemaker( Port5,60 );
//ReefAngel.Wavemaker( Port6,60 );
ReefAngel.Relay.DelayedOn( Port7,3 );
//Actinic Lights
ReefAngel.StandardLights( Box1_Port1,11,0,22,0 );
//Moon Light Driver
ReefAngel.StandardLights( Box1_Port2,22,0,8,0 );
//Morning Lights
ReefAngel.StandardLights( Box1_Port3,11,30,21,30 );
//High Noon Lights
ReefAngel.StandardLights( Box1_Port4,12,0,21,0 );
// This next line will run cooling fans for the tank
ReefAngel.StandardFan( Box1_Port5,790,805 );
//Moon Light 9V
ReefAngel.StandardLights( Box1_Port8,21,59,8,1 );
ReefAngel.PWM.SetDaylight( PWMSlope(12,0,21,0,10,100,240,10) );
ReefAngel.PWM.SetActinic( PWMSlope(11,0,22,0,10,100,60,10) );
if (ReefAngel.Params.Temp[T1_PROBE]>0)
if (ReefAngel.Params.Temp[T1_PROBE] >= 860) ReefAngel.Relay.On(Box1_Port7);
if (ReefAngel.Params.Temp[T1_PROBE] <= 820) ReefAngel.Relay.Off(Box1_Port7);
ReefAngel.Portal( "grafspee1217" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
Re: Outlet cycling
Posted: Fri Sep 28, 2012 9:27 am
You have that port set to heater.
Re: Outlet cycling
Posted: Fri Sep 28, 2012 9:31 am
by grafspee1217
ok, got my boxes mixed up. Box_1 is the second box I added. The main box port 7 which is delayed on for my protein skimmer.
Re: Outlet cycling
Posted: Fri Sep 28, 2012 9:32 am
by grafspee1217
BTW I don't see where I have box_1 port 7 set up as a heater. My heater is on port 1.
Re: Outlet cycling
Posted: Fri Sep 28, 2012 9:37 am
It's in your custom code:
Re: Outlet cycling
Posted: Fri Sep 28, 2012 9:45 am
by grafspee1217
That's for my cooling fan on the lights.
My concern is port 7 for my protein skimmer. I've been wondering why my protein skimmer has been pulling anything out lately.
Re: Outlet cycling
Posted: Fri Sep 28, 2012 9:46 am
by grafspee1217
sorry, I meant to say hasnt been pulling out any skimate
Re: Outlet cycling
Posted: Fri Sep 28, 2012 9:48 am
Got confused here.
Are you talking about port7 or box1_port7 that is presenting that behavior?
Re: Outlet cycling
Posted: Fri Sep 28, 2012 2:54 pm
by grafspee1217
I'm talking about port 7. I have it set for a delayed on. I notice that the port just shuts off and then waits for the delay before it restarts. Question is why is it shutting down?
Re: Outlet cycling
Posted: Fri Sep 28, 2012 2:56 pm
It does that on feeding or water change mode too
Re: Outlet cycling
Posted: Fri Sep 28, 2012 3:22 pm
by grafspee1217
Yes but it was not in either mode when it happened. It happened quite a few times while I was acclimating some corals
Re: Outlet cycling
Posted: Fri Sep 28, 2012 3:48 pm
Does this happen all the time?
Re: Outlet cycling
Posted: Fri Sep 28, 2012 3:51 pm
by grafspee1217
I know but it was not in either feeding or water change mode. The only port that cycled off was port 7.
Re: Outlet cycling
Posted: Fri Sep 28, 2012 3:52 pm
by grafspee1217
I've been watching it now and it happens all the time.
Re: Outlet cycling
Posted: Fri Sep 28, 2012 4:09 pm
If you look in the screen, does it show port7 off?
Re: Outlet cycling
Posted: Fri Sep 28, 2012 4:14 pm
by grafspee1217
I would have to watch it and see. If the screen shows it's off then it's in the code?
Re: Outlet cycling
Posted: Mon Oct 15, 2012 8:13 pm
by SuperDodge
I'm experiencing this behavior on my Box1_Port5 which is also my skimmer. I have it set to DelayedOn but it turns on and off all day long. I am not entering water change mode or feed mode. See Code Below:
// This file is designed for v1.0.2
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define RelayExp
#define InstalledRelayExpansionModules 1
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define SALINITYEXPANSION
#define RFEXPANSION
#define ORPEXPANSION
#define IOEXPANSION
#define FONT_8X8
#define NUMBERS_12x16
The Relay Devices Are:
Salt Mix Pump 1
Return Pump 2
Media Reactor 3
Tank Light 4
UV Sterilizer 5
Not In Use 6
Refugium Light 7
LiterMeter 8
The Expansion Relay Devices Are:
Right VorTech 1
Left Vortech 2
Right Heater 3
Left Heater 4
Protein Skimmer 5
Not In Use 6
Alkalinity Doser 7
Calcium Doser 8
The Vortech Pump Modes Are:
Constant 0
Lagoon 1
Reef Crest 2
Short Pulse 3
Longe Pulse 4
Nutrient Transport 5
Tidal Swell 6
Feeding Start 7
Feeding Stop 8
Night 9
Storm 10
// Define Libraries Used Here:
// End Define Libraries
// Define Global Variables Here:
byte TempRelay1; // Variable for Right Relay Box Statuses
byte TempRelay2; // Variable for Left Relay Box Statuses
byte MoonLight; // Variable that represents Blue LED % for Moonlight
// Variables for Custom Main Screen Layout
byte x;
byte y1;
byte y2;
byte y3;
byte y4;
byte y5;
byte y6;
// End Variable Declarations
// Draw Custom Main Screen:
char phtext[10];
ConvertNumToString(phtext, ReefAngel.Params.PH, 100);
strcat(phtext," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,5,"pH:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,5,phtext);
char saltext[10];
ConvertNumToString(saltext, ReefAngel.Params.Salinity, 10);
strcat(saltext," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,15,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,15,saltext);
char orptext[10];
ConvertNumToString(orptext, ReefAngel.Params.ORP, 1);
strcat(orptext," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,25,"ORP:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,25,orptext);
//ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"RF Mode:");
//ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,ReefAngel.RF.Mode);
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 80, 90, 10); // Display Tank Filter Area Temp
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 80, 100, 10); //Display Tank Temp
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, 80, 110, 10); //Display Room Temp
TempRelay1 = ReefAngel.Relay.RelayData;
TempRelay1 &= ReefAngel.Relay.RelayMaskOff;
TempRelay1 |= ReefAngel.Relay.RelayMaskOn;
ReefAngel.LCD.DrawCircleOutletBox(30, 93, TempRelay1, true);
TempRelay2 = ReefAngel.Relay.RelayDataE[0];
TempRelay2 &= ReefAngel.Relay.RelayMaskOffE[0];
TempRelay2 |= ReefAngel.Relay.RelayMaskOnE[0];
ReefAngel.LCD.DrawCircleOutletBox(7, 93, TempRelay2, true);
// Write Text on Home Screen Temp
ReefAngel.LCD.DrawText(0,255,48,90,"Tank:");
ReefAngel.LCD.DrawText(0,255,111,90,"F");
ReefAngel.LCD.DrawText(0,255,48,100,"Sump:");
ReefAngel.LCD.DrawText(0,255,111,100,"F");
ReefAngel.LCD.DrawText(0,255,48,110,"Room:");
ReefAngel.LCD.DrawText(0,255,115,110,"F");
ReefAngel.LCD.DrawText(0,255,48,120,"pH:");
ReefAngel.LCD.DrawText(0,255,77,120,"ORP:");
// End Custom Main Screen
// One Time Startup Functions:
InternalMemory.ORPMin_write(2050);
InternalMemory.ORPMax_write(450);
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.FeedingModePortsE[0] = Port5Bit;
// Define Ports That Are Always On
ReefAngel.Relay.On(Box1_Port1); // Right VorTech Always On
ReefAngel.Relay.On(Box1_Port2); // Left VorTech Always On
ReefAngel.Relay.On(Port1); // Salt Mix Pump Always On
ReefAngel.Relay.On(Port2); // Return Pump Always On
ReefAngel.Relay.On(Port4); // Tank Light Always On
ReefAngel.Relay.On(Port5); // UV Sterilizer Always On
ReefAngel.Relay.On(Port7); // Refugium Light Always On
ReefAngel.Relay.On(Port8); // LiterMeter Always On
// End Startup Functions
// Main Program:
ReefAngel.StandardHeater(Box1_Port3,778,782); // Control Heater Between 77.8F and 78.2F
ReefAngel.StandardHeater(Box1_Port4,778,782); // Control Heater Between 77.8F and 78.2F
ReefAngel.Relay.DelayedOn(Port3,3); // Turn Media Reactor on 3 Minutes After Startup
ReefAngel.Relay.DelayedOn(Box1_Port5,5); // Turn Skimmer on 5 Minutes After Startup
ReefAngel.DosingPumpRepeat(Box1_Port7,0,60,30); //Run Alk Pump 30 Seconds, Every 60 Minutes
ReefAngel.DosingPumpRepeat(Box1_Port8,30,60,30); //Run Calc Pump 30 Seconds, Every 60 Minutes, 30 Min Phase Shift
// Control Radion Lights
ReefAngel.RF.RadionChannels[Radion_Intensity]=100;
ReefAngel.RF.RadionChannels[Radion_White]=PWMParabola(8,30,22,0,0,100,0);
ReefAngel.RF.RadionChannels[Radion_RoyalBlue]=PWMParabola(8,0,22,30,4,100,4);
ReefAngel.RF.RadionChannels[Radion_Red]=PWMParabola(9,0,21,30,0,5,0);
ReefAngel.RF.RadionChannels[Radion_Green]=PWMParabola(9,0,21,30,0,15,0);
ReefAngel.RF.RadionChannels[Radion_Blue]=PWMParabola(8,15,22,15,0,80,0);
if (second()==0) ReefAngel.RF.RadionWrite();
ReefAngel.Portal("SuperDodge", "xxxxx");
// End Main Program Loop
Re: Outlet cycling
Posted: Mon Oct 15, 2012 8:50 pm
Does Port3 also do the same thing?
Re: Outlet cycling
Posted: Tue Oct 16, 2012 6:55 am
by SuperDodge
I don't believe it does that Roberto, but to be honest I wouldn't swear to it because there is no noise associated with my media reactor so it wouldn't be as obvious.
I'll check it out tonight and see if it's cycling or not.
Re: Outlet cycling
Posted: Fri Oct 19, 2012 7:01 am
by SuperDodge
OK. I was out of town for a couple of days. I watched the controller closely and what's happening is the RA+ is restarting sporadically.
Any ideas?
Re: Outlet cycling
Posted: Fri Oct 19, 2012 8:16 am
Yes, that's what I thought.
If the controller reboots, it would cause the delayedon ports to stay off for that period of time.
Something is causing the controller to reboot. It is usually interference in the system or loose cable.
Re: Outlet cycling
Posted: Fri Oct 19, 2012 11:23 am
by TanksNStuff
Not sure if this is your issue, but I was having a similar problem before and it turned out to be the USB connection to my RF Module (the connector right at the module, not the expansion hub). It wasn't in all the way, and must have been causing an error because it kept timing out my controller (red status light on).
I thought it was maybe the VGA cable or temp probe wires because every time I closed my cabinet door, it would beep and blink. Turns out the temp probe wires were actually tugging on the RF module's cable and jostling it just a tiny bit.
Anyway, I'd check to make sure all of your USB connections are secure to rule out that as a problem.
Re: Outlet cycling
Posted: Mon Oct 22, 2012 5:40 pm
by SuperDodge
I haven't figured out what's causing the RA+ to restart yet, I'm methodically removing one cable at a time.
My question is, am I overdosing Cal/Alk during all this? I have them set on DosingPumpRepeat. Does the timer on that restart every time the RA reboots or does it work based off the clock which doesn't care about the reboots?
Re: Outlet cycling
Posted: Mon Oct 22, 2012 5:53 pm
void ReefAngelClass::DosingPumpRepeat(byte DPRelay, int OffsetMinute, int RepeatMinute, int RunTime)
signed long t=(elapsedSecsToday(now())-((long)OffsetMinute*60));
Relay.Set(DPRelay,(t%((long)RepeatMinute*60))<RunTime && t>=0);
It is based on number of seconds from midnight, so no matter if it reboots or not, it will always use the clock.
Re: Outlet cycling
Posted: Tue Oct 23, 2012 7:12 am
by SuperDodge
rimai wrote:Code: Select all
Thanks, that makes it easier not to worry while I'm trying to sort out what the problem is.
Re: Outlet cycling
Posted: Fri Nov 09, 2012 1:14 am
by grafspee1217
I never did figure out why some of my outlets would occasionally cycle off then back on. It was most noticeable at night when the moonlights were on, kinda hard to miss the lights coming on full bright for a second then off again. I noticed it happened with the skimmer when I was acclimating some corals as well. Since I never got a good answer as to what was causing it I resigned myself to having to live with it. A week ago I noticed the blue light on the wifi blinking. I didnt have time to hook up my laptop and reconfigure the wifi at the time. The next day was my normally scheduled water change day. I set the RA for water change mode and everything shut down as it was supposed to... for about 4 seconds. Then everything started back up again. I tried it again with the same result. No matter what I did it would not stay in water change mode. I tried unplugging the RA with the same result. I noticed that when it happened the screen would blank out for a second then the status light would come on then everything would start up. It seemed as if the RA would simply reboot. Since the wifi was blinking blue I unplugged it from the RA. The problem stopped. I've noticed that since the wifi has not been plugged in (over a week now) I have not had the cycling outlets anymore. any ideas?
Re: Outlet cycling
Posted: Fri Nov 09, 2012 9:58 am
That's a good finding.
I don't know what would cause that though.
Would you be able to post the "get e" dump from the wifi module?
Re: Outlet cycling
Posted: Fri Nov 09, 2012 4:59 pm
by grafspee1217
sure, how do I do that? Does it matter that the wifi module has been off?
Re: Outlet cycling
Posted: Fri Nov 09, 2012 6:25 pm
Look at the manual for instructions on how to use Tera Term.
Outlet cycling
Posted: Sat Nov 10, 2012 7:00 am
by treetopflyn
Hmmm I am having the same issue with cycling on and off. Ill try some of things mentioned and see if anything helps.
