I have a 2-3 month old RA Plus and I can hear it tripping outlets off and on even on outlets that are set to be continuously on. Is this normal behavior? I don't really want it flipping things off and back on sporadically, I doubt my other equipment appreciates it. It does this with my halides off and even with my VHO ballasts off so it can't be interference unless it's interference from my two MP40s.
Thanks in advance,
Gordon
Outlets being tripped w/out schedule
Re: Outlets being tripped w/out schedule
Here it is, I still use the wizard, thanks!
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.FeedingModePortsE[0] = Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port5Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,9,0,21,0 );
ReefAngel.StandardLights( Port2,20,45,9,15 );
ReefAngel.StandardFan( Port7,760,765 );
ReefAngel.StandardFan( Port8,765,770 );
ReefAngel.StandardLights( Box1_Port1,20,0,9,0 );
int x,y;
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
int x,y;
// Relay Expansion
I don't hit the 85 overheat and I seriously doubt I hit the fan off temps except in the middle of the night when I'm not near it (also the relay expansion does it in addition to the main relay).
Gordon
Gordon
Do you have any extension on the temp probes?
Does the red status led turn on?
I'm using all 3 probes and yes one has extensions on it to reach the sump in the floor below the DT.
Status on the head unit is green now, not sure if it ever was red. Should I ditch the extended probe to see if it resolves? It's pretty much the same temp as the DT temp anyway.
Cheers,
Gordon
Cheers,
Gordon
