Outlets being tripped w/out schedule
Posted: Sat Oct 06, 2012 7:03 am
by garcastle
I have a 2-3 month old RA Plus and I can hear it tripping outlets off and on even on outlets that are set to be continuously on. Is this normal behavior? I don't really want it flipping things off and back on sporadically, I doubt my other equipment appreciates it. It does this with my halides off and even with my VHO ballasts off so it can't be interference unless it's interference from my two MP40s.
Thanks in advance,
Gordon
Re: Outlets being tripped w/out schedule
Posted: Sat Oct 06, 2012 8:55 am
Can I see the code?
Posted: Sat Oct 06, 2012 10:14 am
by garcastle
Here it is, I still use the wizard, thanks!
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.FeedingModePortsE[0] = Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port5Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,9,0,21,0 );
ReefAngel.StandardLights( Port2,20,45,9,15 );
ReefAngel.StandardFan( Port7,760,765 );
ReefAngel.StandardFan( Port8,765,770 );
ReefAngel.StandardLights( Box1_Port1,20,0,9,0 );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
Posted: Sat Oct 06, 2012 10:16 am
by garcastle
I don't hit the 85 overheat and I seriously doubt I hit the fan off temps except in the middle of the night when I'm not near it (also the relay expansion does it in addition to the main relay).
Gordon
Posted: Sat Oct 06, 2012 11:09 am
Do you have any extension on the temp probes?
Does the red status led turn on?
Posted: Sat Oct 06, 2012 4:25 pm
by garcastle
I'm using all 3 probes and yes one has extensions on it to reach the sump in the floor below the DT.
Status on the head unit is green now, not sure if it ever was red. Should I ditch the extended probe to see if it resolves? It's pretty much the same temp as the DT temp anyway.
Cheers,
Gordon
Posted: Sat Oct 06, 2012 4:34 pm
Do you know which ports that toggle?
