Delay doesn't appear to be working
I'm a little confused. I use a mac with the wizard to program my reefangel. I have one question and one request:
1. The request is that the wizard would allow each of the relay ports to be named since I have trouble remembering what all I have plugged in to each of my 16 relays.
2. The question is this... I'm running my skimmer on timer mode since I want a 30 minute period when I'm putting in plankton to not run the skimmer. I have added a 15 minute delay, so that after feeding mode when my sump has higher water volume in it, I'd rather not run the skimmer until the sump water level is lower and thus the skimmer won't accumulate wet skimmate from a temporarily high sump water volume. Am I correct in thinking that the delay should give a delay in 15 minutes after restart from feeding mode?
Thanks....
Thanks....
Re: Delay doesn't appear to be working
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port7Bit;
ReefAngel.LightsOnPorts = Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port5Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardLights( Port1,0,30,0,0 );
ReefAngel.StandardLights( Port3,12,0,19,0 );
ReefAngel.StandardFan( Port4,776,786 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.WavemakerRandom( Port6,60,100 );
ReefAngel.StandardHeater( Port7,751,761 );
ReefAngel.StandardHeater( Port8,746,761 );
ReefAngel.StandardLights( Box1_Port4,9,0,10,16 );
ReefAngel.StandardLights( Box1_Port5,9,0,19,0 );
ReefAngel.StandardLights( Box1_Port6,7,0,8,16 );
ReefAngel.StandardLights( Box1_Port8,14,0,8,0 );
ReefAngel.Portal( "erikweitzel" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
ReefAngel.LCD.DrawOutletBox( 12, 76, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
int x,y;
// Salinity
// Relay Expansion
You don't have any port with delay.
Are you sure you picked Delayed Start?
I'm pretty sure. Here's a screen shot of my Port 1 on Relay 1. Am I doing something wrong?
- Relay 1.jpg (122.25 KiB) Viewed 5818 times
That time delay is for halide ballasts as mentioned on the description. It only works on power up.
If you want for feeding/water change mode, you must use the Delayed option.
Thanks. I got confused. Appreciate the help.
I guess I can add one to the request list:
1. Able to label ports in the wizard
2. Delay mode create a "rest" period for the port to allow dosing of plankton and prevent skimming during that interval.
What do you mean as "rest" period?
The port would be delayed x minutes before it turns on. Isn't it a "rest" period?
I have programmed dosing pumps to put in about 10mL of plankton at midnight. I would like the skimmer to stop functioning from 0000-0030 so that the plankton gets to circulate prior to being skimmed. Thus the rest period. Since I'm not manually feeding the tank it was never placed in a feeding mode. Makes sense?
Oh, that's what I was getting confused.
You don't want the delayed on function at all then.
Why don't you just place the skimmer as time schedule to turn on at 0:30 and turn off at 0:00??
I originally did that but I was running into problems after running the feed mode when the water will rise in the sump. When the system restarts after feed mode lapses, the skimmer would not have a delay and then overflow. I kind of need a hybrid of delay mode and timer mode.
Ahhh.
You need a custom code then.
Setup the port as delayed on, then use this custom code too:
if (hour()==0 and minute()<30) ReefAngel.Relay.Off(Port1);
