Led
dbmet
Led
Post by dbmet »
How many led drivers can I run off the standard analog unit on the dimming ports?
Re: Led
Which driver?
I tested Meanwells and you would be good for up to 4. If you need more than 4, let me know.
dbmet
Re: Led
Post by dbmet »
I was considering this
Actinic-- 1 Inventronics + 2 Meanwells
White -- 1 Inventronics + 2 Meanwells
Re: Led
I think you should be fine.
Led
rimai wrote:Which driver?
4 per port or four total?
Re: Led
4 per port.
Technically speaking, you can do many more.
If I remember correctly, up to 13 meanwells. I think each meanwell was drawing 3mA when put to 100%.
Each dimming port can source 40mA. So you do the math.
As long as the drivers are not pulling more than 40mA, you are fine stacking them up.
