Alrighty then. Glued the pieces together with primer and pvc cement, and zip tied it to the sump drain pipe. Very tight and secure.
Uploaded some code from the wizard so that the water level calibration showed up on the head unit. Calibrated the switch and set it back in place. Very simple and straightforward.
Where my PVC tube sat, the RA read around 42. I uploaded alexwbush's code, with values of 45 and 40, instead of 62 and 60, and changed his port5 to port1 for my ATO pump.
The code compiled and uploaded fine, and the ATO pump was not on initially, as was expected. Then, I took a bucket of water out of the sump, so that the level fell to about 38. The pump turned on and started to fill, as it should. However, when the level got close to 40, the pump switches off and on, rather than filling to 45, and then turning off. What am I missing?
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.StandardLights( Port2,6,0,23,0 );
ReefAngel.StandardLights( Port3,13,0,22,0 );
ReefAngel.StandardLights( Port4,14,0,18,0 );
ReefAngel.Wavemaker( Port5,6 );
ReefAngel.StandardHeater( Port7,766,770 );
byte topofflevel=40;
// If water level less than 40, turn on auto top off relay; else, keep it off
if (ReefAngel.WaterLevel.GetLevel()<topofflevel)
topofflevel=45;
ReefAngel.Relay.On(Port1);
topofflevel=40;
ReefAngel.Relay.Off(Port1);
// If water level equals 0, turn off return relay; else, keep it on
if (ReefAngel.WaterLevel.GetLevel()==0) ReefAngel.Relay.Off(Port8);
else ReefAngel.Relay.On(Port8);
ReefAngel.Portal( "barbianj" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
// Date and Time
