Dimming curves... LED
Posted: Thu Oct 11, 2012 1:23 pm
by jg210302
I was wondering if there is already code setup in the controller out of the box for dimming LED's? Currently I am building a new fixture with dimming. If I use the Actinic and daylight plugs on the relay box that are already on timers to shut them off and turn them on and then connect the dimming ports to my new power supplies is there already an exsisting dimming curve?
Also is the code easy to change as far as the dimming? I want to adjust the max voltage so I can aclimate new corals...
Thanks in advance,
Jeremy
Re: Dimming curves... LED
Posted: Thu Oct 11, 2012 1:33 pm
Out of the box you have a parabola wave form for both channels.
You can change it to a slope shape, but would require you to upload another code.
Posted: Thu Oct 11, 2012 1:38 pm
by jg210302
rimai wrote:Out of the box you have a parabola wave form for both channels.
That is exactly what I want, is there an easy way to change the max intensity, or would I have to change the code?
Posted: Thu Oct 11, 2012 1:52 pm
Press the joystick to access menu and go to LED setup.
You will be able to set the max intensity for both channels individually.
You can find more info on the user manual.
Posted: Thu Oct 11, 2012 1:57 pm
by jg210302
rimai wrote:Press the joystick to access menu and go to LED setup.
Thank you sir!!!!
