Client not showing data
Posted: Thu Oct 11, 2012 3:17 pm
by wmhampton
So I have owned this controller for quiet some time and never been able to get this function to work. On the bottom it shows
"Listener: Running / Connected | Logger: Running | DB Version 2.2 | Dev Lib Version: x.x.x.xx |"
However no information is being sent to it...
So lost on what to do
Thank you for any help you can give
Re: Client not showing data
Posted: Thu Oct 11, 2012 3:41 pm
Can I see your code?
Posted: Thu Oct 11, 2012 3:44 pm
by wmhampton
it is just the stock code that came with it, i never bothered to figure any of that out since it had all the functions i required.
Do you have an RA or RA+?
Posted: Thu Oct 11, 2012 3:46 pm
by wmhampton
RA
Posted: Thu Oct 11, 2012 3:51 pm
It won't do it on the preloaded code.
You must enable the wifi framework to be able to communicate with the Client and the standard RA doesn't have wifi enabled on the preloaded code due to memory size constraints.
Posted: Thu Oct 11, 2012 3:52 pm
by wmhampton
O boy!! How difficult is this to tackle?
Posted: Thu Oct 11, 2012 3:53 pm
Use the Wizard to create your own code and make sure to enable wifi.
Open Arduino and go to menu Tools->Reef Angel Wizard
Posted: Thu Oct 11, 2012 4:10 pm
by wmhampton
Alright that was pretty simple to go through and figure out. However when I try to generate and upload it says an error has occurred please try again
