Multiple RA Units
Posted: Sun Oct 14, 2012 1:35 pm
by carlii
Ok. So I have a RA on my 120 mixed reef. I was out of three days and my RTA in my was ready to die in my 46 gallon because the water level dropped which raised the salinity. So, I hate wasting money. I need an ATO, I bought a wave l maker controller. And now I realize, again that a RA is cheaper than the route I am taking.
So I am considering buying another controller. My question is, how would I control two RAs remotely? I use my iPhone and the web portal extensively.
Re: Multiple RA Units
Posted: Sun Oct 14, 2012 1:42 pm
Android supports 2 profiles to be setup, but not the iphone
The Portal also does not offer 2 profiles due to how the forum/database is setup, but you could always logout and login with another username to change the portal userid.
Posted: Sun Oct 14, 2012 2:34 pm
by carlii
What about using different port numbers? The ports would have to be different right?
Posted: Sun Oct 14, 2012 4:58 pm
correct
Posted: Sun Oct 14, 2012 5:50 pm
i have 2 ra units on my home network and just use 2 different ports on my router for access outside my network.
Posted: Mon Oct 15, 2012 11:16 pm
by alexwbush
I run 2 as well. They're at different locations, but I will run different ports. To run portal, you'll have to create two profiles. But we'll fix that one day... right Roberto?
