Temp 1 stuck on and high
Posted: Sun Oct 14, 2012 9:56 pm
well i got every thing going and used the set up wizard. But im having an issue with the first temp probe slot or T1 as it is labeled. T2 and T3 all work fine. I tried to change temp probes and see if it was a bad probe that was causing the high temp reading, its not a bad probe. Its reading 91+ degrees and the other two are both in range of the separate. i know you must reboot to get the temp to recognize the probe. I have multiple times regenerated the code and reloaded it to the reef angle. Even with the temp probe not plugged in it reads 91+ degrees and even after multiple reboots with the wizard. Ive tried all that i can think of. im not to good with writing/reading code well i have no idea how to write/read it.
here is my code if it helps. I am very good at deleting and copy and pasting
thanks for your help
ReefAngel.FeedingModePorts = Port6Bit;
ReefAngel.WaterChangePorts = Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 821 );
ReefAngel.StandardLights( Port1,12,0,21,0 );
ReefAngel.StandardLights( Port2,13,30,19,0 );
ReefAngel.StandardHeater( Port3,759,770 );
ReefAngel.StandardFan( Port4,776,788 );
ReefAngel.StandardLights( Port5,20,45,12,4 );
ReefAngel.StandardLights( Port7,20,59,11,59 );
