PWM Expansion needed?
Posted: Tue Oct 16, 2012 7:15 pm
by najluni15
Hi,
I am planning a new build with 4 Meanwell drivers, or 4 Steve's LED drivers. Is it possible to connect 2 drivers into EACH PWM channel already included with my current Reef Angel? And if so, how would I do this.
Thank you so much.
Re: PWM Expansion needed?
Posted: Tue Oct 16, 2012 8:16 pm
yes, you can.
Just connect them in parallel.
Posted: Tue Oct 16, 2012 8:25 pm
by najluni15
Is there a limit to how many I can connect to each PWM channel? I plan on having three drivers for one channel, and another 2 on another channel for around 60 leds total.
Thanks so much. Your support is awesome as always...Now this enables me to pick up a wifi adapter instead of the pwm!
Posted: Tue Oct 16, 2012 8:29 pm
There is but you should be fine with 3.
The limitation is 40mA draw from all drivers when they are at 100%.
Each meanwell I think draws around 3mA.
Posted: Tue Oct 16, 2012 8:31 pm
by najluni15
Thanks Again! And do you know if it is possible to dim the meanwells to 0%? Apparently they cut out at 15%, according to another thread. Im trying to decide between the Steves LeD Drivers and the mean wells.
Posted: Tue Oct 16, 2012 8:33 pm
LPF series is supposed to go down to 3%. ELN series cut off at around 15%
I've heard Steve's go all the way to 1%.
Since you brought up Steve's...let me hijack with a quick question...can you have a pot and pwm with the meanwell's? Steve's has a separate input for a manual dimmer in addition to the pwm input...
Posted: Tue Oct 16, 2012 8:34 pm
lnevo wrote:Since you brought up Steve's...let me hijack with a quick question...can you have a pot and pwm with the meanwell's? Steve's has a separate input for a manual dimmer in addition to the pwm input...
Really?
You can have both?
Posted: Tue Oct 16, 2012 8:36 pm
by najluni15
What is the difference between the LPF and ELN series? Sorry if this is unrelated to you, but it seems like you know a lot about it...
Posted: Tue Oct 16, 2012 8:37 pm
Right after I posted, I was like, duhh!!??
Of course you can.
If you pot the dimming signal, you get to feed the driver a % of the dimming signal, which makes it double dimming if you will... lol
Posted: Tue Oct 16, 2012 8:39 pm
LPF is their newer model. Never used it though. Sebyte (Steve) and 00Warpig00 (Nick) are using them.
http://forum.reefangel.com/viewtopic.php?f=2&t=788
Posted: Tue Oct 16, 2012 8:57 pm
by najluni15
Ill have to look into it. Thanks!
