I am trying to decide on what I want to get and I am leaning towards the Standard Reef angel. I have read that the Wifi Attachment is a memory hog.
Setup.
reef angel will control on and off for all 8 outlets 2 of witch will control timer for lights. Nothing fancy
I will have auto top off set up.
Will use temp sensor to control heaters.
don't think I will use wave maker;however, might mess around with it.
In the future probably March2013 , I will get a second reef system up and running. I will add an outlet relay and a temp prob to control this system.
The question is how much can a standard RA control. 3 or 4 expansion modules is idea, but I don't foresee myself using that many till probably end of summer. My magic number for a controller is 350 my wife said don't go above that. that is why I ask this question. It most have wifi also per wife's request she wants to play with online app.
Thank you.
will the Standard RA be enough for my simple setup
Re: will the Standard RA be enough for my simple setup
You can use the standard RA for now and upgrade later too.
