Light control menu vanished
dnastynice
Post by dnastynice »
I have used the wizard for every thing every thing so far been working very well. the other day i went to turn my light on after dark and the light menu was gone. so i cant do "lights on" ect Also i have my diy leds and the controls to adjust the intensities are also not there. here is my code:
    ReefAngel.WaterChangePorts = Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port5Bit | Port6Bit;
    InternalMemory.OverheatTemp_write( 821 );
    ReefAngel.StandardLights( Port1,12,0,21,0 );
    ReefAngel.StandardLights( Port2,13,30,19,0 );
    ReefAngel.StandardHeater( Port3,759,769 );
    ReefAngel.StandardFan( Port4,770,788 );
    ReefAngel.StandardLights( Port5,20,45,12,4 );
    ReefAngel.StandardLights( Port7,20,59,11,59 );
    ReefAngel.PWM.SetDaylight( PWMParabola(9,1,20,0,65,89,65) );
    ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,89,94,89) );
    ReefAngel.Portal( "dnastynice" );
Re: Light control menu vanished
You can override the ports and change settings on android phone or Portal :)
But, if you need the menu back, you can add this line to setup() section:
ReefAngel.AddStandardMenu();
You won't be able to change settings though. Your code uses hard coded settings.
Actually... I withdraw my last comment.
You can't change settings on android phone or Portal either.
All your settings are hard coded.
If you change to memory settings, you will be able to change the settings on android phone and portal.
You can override ports on any of them though.
dnastynice
well how do i change that ? i want to be able to change it on my droid and controller
You need to choose memory settings when generating your code with Wizard then.
dnastynice
thank you casper for the hook up and custom screen and menus!!
CASPAR
Post by CASPAR »
No problem!!!!
