Reef Angel Libraries Update Utility
Posted: Sat Mar 19, 2011 2:20 pm
by reefangel
Hello Everyone,
This little application checks which version of libraries you currently have and also gives you the option to download the latest libraries.
http://www.reefangel.com/update
Works for both MacOSX and Windows.
Happy coding,
Roberto Imai
Re: Reef Angel Libraries Update Utility
Posted: Sat Mar 19, 2011 2:33 pm
by binder
Where is this application located?
Posted: Sat Mar 19, 2011 2:39 pm
by reefangel
binder wrote:Where is this application located?
Edited the original post
Posted: Fri Sep 30, 2011 1:37 pm
by chase
This app is totally amazing, why not post it under downloads?
Posted: Fri Sep 30, 2011 5:20 pm
I'll add it to the website :)
Posted: Wed Oct 05, 2011 10:05 am
by chase
rimai wrote:I'll add it to the website :)
Huzzahh!
Posted: Wed Oct 05, 2011 10:42 am
Huzzahh!
:) Thanks for the suggestion.
Posted: Fri Oct 07, 2011 7:16 am
by chase
No probs, there's tons of good stuff squirreled away on these forums. Just gotta grab it up when you stumble across it and find a spot to put it.
Posted: Fri Oct 07, 2011 5:44 pm
by binder
I try to keep some of my "more important" things stickied at the top of the forums if I can. It's a feeble attempt to help everybody out. :)
Posted: Sat Oct 08, 2011 11:27 pm
by chase
binder wrote: I try to keep some of my "more important" things stickied at the top of the forums if I can. It's a feeble attempt to help everybody out. :)
Yeah, good idea. Since getting my controller up and running over the past 3-4 weeks I've definitely accumulated quite an amount of bookmarks covering various posts along with good tips here and there. I was planning on putting them together in the newbie forum as a kind of "Things I learned along the way" that weren't necessarily obvious or maybe confusing at first. Figured it would help people get their feet wet and scale back the 'omg wtf did i get myself into' factor, lol.
Posted: Sun Oct 09, 2011 5:22 pm
That would be nice to have... :)
Can you write up something?
Posted: Wed Oct 19, 2011 3:42 am
by chase
rimai wrote:That would be nice to have... :)
Yep, wrote it up under the newbie section - http://forum.reefangel.com/viewtopic.php?f=15&t=369
Posted: Wed Mar 28, 2012 8:26 am
It works for both MacOSX and Windows now.
Posted: Wed Mar 28, 2012 3:11 pm
by Sebyte
There has been a link to Chase's write up in the "where to start guide" from the first edition. I thought it was a very usefull artical from the view point of a nubie at that time.
Posted: Fri Jun 29, 2012 8:16 am
by rufessor
Quick Suggestion.
The Update Wizard seems like it is configured to look at the server and find the latest library version, display that and ask you to update... but it does not seem to be looking at your local config to determine if its really an update.... I.E. after updating and running the Wizard again, its asking if I want to install what I just installed. Its kinda easy to miss that the last digit changed and then you may fail to sequentially update to newest, or you might (as I did once) just re-install what you only moments before installed.
Would it be possible to just write a file somewhere local that indicates the last update installed and then compares to latest on server and then only if they are different asks you to update... else it just says... your up to date no need to do anything.
Not a big deal at all... but it would essentially guarantee that everyone is fully up to date (you just update until it tells you your updated to latest) and avoid redundant downloads and uncertainty.
It may be that a yet newer version exists that does this...
Posted: Fri Jun 29, 2012 8:59 am
This update utility has an end soon to be reached :(
I've got goodies under my sleeves :twisted:
The new Arduino IDE that will be released in the next few days will actually have an auto-update feature.
It will check and compare versions automatically everytime you start the Arduino IDE.
It is actually going to be a global update utility, where it downloads the following:
RA libraries
All current and future Tools - Libraries version, Restore Preloaded and Wizard
Example Codes
Features auto-selection keyword file
Pretty cool, huh?
I had to compile my own version of the Arduino IDE and change some stuff around, but the end result will be awesome :mrgreen:
Posted: Fri Jun 29, 2012 9:16 am
by rufessor
HAHAHA!
Awesome! Thats a big shirt your wearing to fit all that under your sleeves!!
This will be very nice.... greatly simplifying things and will completely kill off all posts about known bugs in prior versions... Awesome!
Once again.... you have been busy!
Posted: Fri Jun 29, 2012 10:53 am
by astralmind
Awesome stuff! Can't wait to try this out
