Stray voltage monitor
barbianj
It seems like a simple thing, but it can cause big problems and frustration. Would there be a way to monitor for stray voltage and have the RA send an alert when it is above a certain level? IMO, it would be worth the price of a module to know when a pump is going out before it dies, or kills coral or fish. Proactive rather than reactive.
- jsclownfish
Re: Stray voltage monitor
I find my pH probe is a pretty good stray voltage detector.
Jon
Jon
barbianj
Haha, just proves my point.jsclownfish wrote:I find my pH probe is a pretty good stray voltage detector.![]()
Jon
- jsclownfish
Yep, I just had a flow meter go bad and I knew it because my pH probe started reading a pH of 2.
I knew it right away as the portal sent me an alarm. This reminded me I used to have a grounding probe in my tank, but I haven't used it in years. A voltage read in the tank water would be cool though as you might see trends in the levels as well.
Jon
Jon
mcgyvr
There is always stray voltage in your tank. Pumps/lights,etc.. all emit "some" level of voltage into the surrounding air/water. Its the flow of current that "can" cause a problem.
A simple GFCI outlet or power strip with GFCI is all you need for an indicator. And I hope you all have one on your tanks already as its a MUST with any aquarium or body of water where you place submersible electrical devices into.
It will save your life. If you don't have one get one NOW.
A GFCI will shut down your system when a leakage of anything over 5 milliamps of current is detected. They are in your bathrooms and kitchens already..
