wifi sends, but will not receive
Posted: Sat Oct 27, 2012 12:52 pm
by wolfpack
I apologize if this has been discussed before, I didn't find that thread.
This controller has been setup for about 2 months. It worked great for the first month. I then went off for my 5 weeks away from my tank (luckily only 3 hours north) and it stopped working after about 3 days. Well, it managed to half come back and it's been in this state ever since. The data is pushed by the controller, but it won't receive.
So when I look at my portal, I see that it's getting updates every 3-5 minutes and the light on the wifi module looks correct (green with long pauses), but it says "Connection Status: Unreachable Address" which means I can't update any settings from the portal or android app.
Any help or insight is greatly appreciated.
Re: wifi sends, but will not receive
Posted: Sat Oct 27, 2012 1:07 pm
by dbmet
Is your home ip address the same as whats listed on the Portal? Some times your internet provider changes your address causing issues?
d
Posted: Sat Oct 27, 2012 1:52 pm
Or your wifi attchment changed ip address.
Double check your port forwarding.
Posted: Sat Oct 27, 2012 2:44 pm
by wolfpack
thanks for the inputs. It as that my wifi attachment changed ip addresses and so my port forwarding wasn't matched up. I'll have to reassign it to a static address... oy!
Thanks!!
