Reef Angel Controller Web Server”
Posted: Sun Oct 28, 2012 3:58 pm
by lartho6
how do i get access the Reef Angel Controller Web Server every time i try to load do it says its not a there, im tryin to connect my wifi adapter to the controller
Re: Reef Angel Controller Web Server”
Posted: Sun Oct 28, 2012 4:03 pm
Upload the WifiTestCode and try again.
Posted: Sun Oct 28, 2012 4:16 pm
by lartho6
ok i think im doing something wrong.. heck i been doing that all day.. since 3 a.m. lol so what do i need to put in the http://xxxx.xxxx.xxxx.xxxx:2000 my ip address?
Posted: Sun Oct 28, 2012 4:17 pm
yeap
Posted: Sun Oct 28, 2012 4:25 pm
by lartho6
http://172.16.0.2:2000 is what i did and it says it cant establish a connection to the server. i think i been working at this too long.. but im loving it thanks for the help
Posted: Sun Oct 28, 2012 6:23 pm
if you are still having problems, make sure that your controller is actually connected to your network. open up your router's web page and confirm that it is connected.
you can also try to "ping" your controller. type "ping 172.16.0.2" from a command prompt and see if you get any replies back. if you do not, then your computer is not communicating with your controller and there is some form of connection problem.
check that you have the correct SSID and password set on the wifi module and that it's connected to your network.
that's what I would start with first.
Posted: Sun Oct 28, 2012 7:17 pm
by lartho6
roberto and i got the module working a few hours ago i will open the routers web page and see if its connectd
Posted: Mon Oct 29, 2012 4:35 am
by lartho6
ok checked my router to see if the wifi module was connected it seemed to be. but i still cant get the address to pull up. i did send the wifi test code to the controller, i dont know what im doing wrong
Posted: Mon Oct 29, 2012 6:59 am
Just to make sure, you connected with wifi attachment to RA with the provided cable, right??
And you have the cable with black wires to the right most pin, right?
Posted: Mon Oct 29, 2012 7:56 am
by lartho6
ok its is.. and just the green light is blinking slow, its connected to my router. the http:...... page isnt working for me.
Posted: Mon Oct 29, 2012 9:44 am
by lartho6
Is there any other way to get this page to open.. or did i not install something to the controller the right way?
