2.2 Load Memory File
Bryan
Wondering about the "Load Memory file" feature. Where does one get the memory file from. Don't see RA Gen creating one, unless it's the generated PDE.
-=Bryan=-
- Contact:
Re: 2.2 Load Memory File
I haven't used 2.2 yet, but from talking with Dave about some of the features, I think this has to do with a memory map file. You have the ability to change the memory locations around IF I ever changed them on the controller. This would ensure that the client would write the values to the proper spot.Bryan wrote:Wondering about the "Load Memory file" feature. Where does one get the memory file from. Don't see RA Gen creating one, unless it's the generated PDE.
So I'm thinking this is what / how you would do it. If not, then I don't know what this option is for.
Bryan
I thought perhaps it was to reload the Memory settings if one flashes the controller and erases the EEPROM. Would be handy rather than having to re-populate all the fields etc.
-=Bryan=-
dmolton
This is indeed the intended purpose of the function.binder wrote:I haven't used 2.2 yet, but from talking with Dave about some of the features, I think this has to do with a memory map file. You have the ability to change the memory locations around IF I ever changed them on the controller. This would ensure that the client would write the values to the proper spot.
It would be. Haven't figured out how to compile/upload to the controller from .NET yet.. Still relying heavily on the dev libraries and #define wifi for all communication with the controller.Bryan wrote:I thought perhaps it was to reload the Memory settings if one flashes the controller and erases the EEPROM. Would be handy rather than having to re-populate all the fields etc.
