Re: PWM Dimmer Freq?
Posted: Wed Nov 07, 2012 12:02 pm
Posted: Wed Nov 07, 2012 12:20 pm
by jerkyjunky
Perfect. My driver needs 100-5000 hz. Just wanted to make sure before I purchase.
I've heard complaints from other sites about Apex VDM putting out over 10V and hurting some drivers because of that. Have you heard any issues with the RA putting out > 10V? I assume though with this setup you could program the unit to put out a % less than 10V in the code so the actual output is 10V?
Posted: Wed Nov 07, 2012 2:15 pm
No, the signal will not go over 10VDC.
