PH Expansion Not Showing
Posted: Sun Nov 11, 2012 5:18 am
Can anyone please assist?
The PH Expansion is not showing up at all
ReefAngel.LCD.DrawDate(6, 64);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 19, 4 , "BOBS REEF");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 33, 15, "Tank Water");
char text[7];
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 15, 26, text);
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 60, 26, text);
ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 15, 35, "pH");
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 15, 42, text);
ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 60, 35, "pH2");
ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 60, 42, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,84,"ATO");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,94,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,104,"CO2");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,114,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,84,"Return");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,94,"Vortech");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,104,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,114,"Heater");
ReefAngel.LCD.DrawCircleOutletBox(60, 86, TempRelay, true);
InternalMemory.OverheatTemp_write( 260 );
ReefAngel.SingleATO( true,Port2,60,0 );
ReefAngel.StandardLights( Port3,4,0,23,0 );
ReefAngel.StandardHeater( Port7,250,255 );
if (ReefAngel.Params.PHExp <= 735) ReefAngel.Relay.Off(Port6); // If probe 2 PH <= 7.35 - turn off CO2
if (ReefAngel.Params.PHExp >= 752) ReefAngel.Relay.On(Port6); // If probe 2 PH >= 7.52 - turn on CO2 if (ReefAngel.Params.PH <= 790) Relay.Off(Port6); // If PH <= LowPH - turn off CO2
if (ReefAngel.Params.PH <= 790) ReefAngel.Relay.Off(Port6); // If probe 1 PH <= 7.90 - turn off CO2
ReefAngel.Portal( "Lockes" );
