DrawCircleOutletBox - Horizontal?
Posted: Fri Nov 16, 2012 2:29 pm
I'm not sure if someone posted this before or not, but I was coding my display and saw people with the circle outlet options and thought it was great. However, the one already in RA_NokiaLCD.cpp is vertical, and since my relay box is mounted horizontal, not that awesome. I added a new function to the code and wanted to share it. Always like to give to communities that give back. Let me know what you think.
void RA_NokiaLCD::DrawCircleOutletBoxHorizontal(byte x, byte y, byte RelayData)
// altered version of DrawCircleOutletBox by JerkyJunky
// designed for a layout where the plugs are aligned like:
// 8 6 4 2
// 7 5 3 1
//Variables:
byte offset = 5; //distance between given x,y location and the center of first circle
byte a = 0; //our counter of relay port
byte b = 3; //horizontal column counter
byte c = 1; //vertical row counter
//Main Loop - Starting at port 1 work our way up and left
for (a=0;a<8;a++)
DrawCircleOutline((b*10) + x + offset, (c*10) + y + offset, 5, OutletBorderColor);
//check if relay is active and color appropriately
if ((RelayData&(1<<a))==1<<a)
FillCircle((b*10) + x + offset, (c*10) + y + offset, 3, OutletOnBGColor);
FillCircle((b*10) + x + offset, (c*10) + y + offset, 3, OutletOffBGColor);
//adjust counters for next circle (up and left)
if (c == 0)
c = 1;
b = b - 1;
c = c - 1;
