Ph won't read anything other than 6.99
Posted: Sun Nov 18, 2012 12:52 pm
by mineman@mac.com
Just like the title says. Have tried putting it in tap water, rodi, new NSW, always 6.99. Tried power cycling, no luck.
Re: Ph won't read anything other than 6.99
Posted: Sun Nov 18, 2012 2:23 pm
Did you try recalibrating?
Posted: Sun Nov 18, 2012 2:26 pm
by mineman@mac.com
Not yet, I'm out of packets but I just calibrated a few months ago. Is this normal?
Posted: Sun Nov 18, 2012 2:57 pm
by mineman@mac.com
I think the change might have happened when I updated my libraries. Would this cause a deletion of calibration?
Posted: Sun Nov 18, 2012 3:15 pm
Can I see your code?
Posted: Sun Nov 18, 2012 3:17 pm
by mineman@mac.com
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.SingleATOLow( Port1 );
ReefAngel.DayLights( Port3 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.StandardHeater( Port8 );
ReefAngel.Portal( "mineman@mac.com" );
Posted: Sun Nov 18, 2012 4:29 pm
Let's try this:
ReefAngel.PHMin=550;// 550=PH7.0
ReefAngel.PHMax=830;// 830=PH10.0
Posted: Sun Nov 18, 2012 5:40 pm
by mineman@mac.com
Worked! Thank you!
