				Portal unreachable adress
				Posted: Tue Nov 20, 2012 7:01 pm
				by AquaO
				I have an error on the portal ''unreachable adress'' and the iphone ''Unable to connect'' I configure the wifi with my router with DNS. The module blinking green and I have access to the temperature, ph and orp but I'm not able to set the relay or accessed in memory. Same thing with the iphone.
I dont have a 2 way comunication only read.
Thank Eric
				Re: Portal unreachable adress
				Posted: Tue Nov 20, 2012 7:32 pm
				by Sebyte
				Have you setup port forwarding on your router?
				Posted: Tue Nov 20, 2012 7:54 pm
				by AquaO
				Sebyte wrote:Have you setup port forwarding on your router?
Sorry I do not know how? I assume that it's in the router configuration?
				Posted: Tue Nov 20, 2012 7:59 pm
				by Sebyte
				The manual for your router should have the instructions. If not Google your router type and port forwarding.
Also have a look at
http://en.wikipedia.org/wiki/Port_forwarding
				Posted: Tue Nov 20, 2012 8:03 pm
				by dbmet
				Some people have had luck using this site..
http://www.simpleportforwarding.com/
				Posted: Tue Nov 20, 2012 10:08 pm
				by barbianj
				With a newer router, you may be able to log in and do it through the browser. Check that the router's firmware is up to date, also.
				Posted: Sat Nov 24, 2012 10:40 am
				by AquaO
				Thank you very much for your help, after several hours reading and trying, the portal works correctly.
It is only now around 10 am that everything works correctly.
One small thing is that the web banner does not seem to update.
If I change the name of the relay it's updated but not the data.
I think the problem comes from the portal ...
Have you any idea?
				Posted: Sat Nov 24, 2012 1:46 pm
				That means the controller is still not sending data to the server.
Check if you have the Portal() function in your code.
Which application did you use to configure the wifi attachment?
				Posted: Sat Nov 24, 2012 3:58 pm
				by AquaO
				Everything works in the portal, I can activate ports (on/off) it's only the banner and the iphone app does not work.
I configured the wifi expansion with Dns button (wifi and router) for generated my code I use the wizard.
This is my code:
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port4,16,0,22,0 );
    ReefAngel.DosingPumpRepeat( Port8,0,60,70 );
    ReefAngel.Portal( "AquaO" );
    int x,y;
    // Parameters
    // ORP
    ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,66, "ORP:" );
    ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,66, ReefAngel.Params.ORP );
    // Main Relay Box
    // Date and Time
				Posted: Sat Nov 24, 2012 10:10 pm
				by AquaO
				The portal has run well all day (turn on/off relay) and good data (temp,ph,orp), but now sometimes it disconnects and I have a unreachable adress and other times it's ok.
This is my setup:
Reef Angel wifi address: 70.82.xx.xx:2000
My virtual server:
Service Name          Port Range          Local IP         Local Port          Protocol
  reefangel              2000:2000        192.168.1.2        2000                 TCP
I used the WPS button for wifi/router and I use the wizard for the code
The banner and iphone app not work.
Thank you for your help
				Posted: Sun Nov 25, 2012 5:16 am
				May I ask to use Dave's utility and pull the wifi settings?
You can download the utility on the contribution download page of the website.
				Posted: Sun Nov 25, 2012 7:51 am
				by AquaO
				yes I also try with wifi utility without success ... tell the truth it's been several days that I try several configurations.
I will ask a friend who knows the network to help me.
Thank you
				Posted: Sun Nov 25, 2012 12:34 pm
				ok, can you post the results of "get e" command when you use Tera Term?
