Setting up Salinity expansion Unit
Posted: Wed Nov 21, 2012 8:05 pm
We installed our new Salinity Probe today and need some guidance on what we are (or are not) seeing. First, I wish the documentation had some pictures. It wasn't clear to me if the salinity probe needed some sort of cover removed prior to sticking it in the water. The small barrel at the end of the has a small hole in it to let in water so we did not attempt to remove what might of been a kind of cover.
Second, I am seeing the same results posted in another similar post, sal=59, and when I attempted to calibrate it remained at zero.
Finally, I uploaded and ran the code included in the examples but was unclear as to what results I should have seen from running the code.
Thanks for your advice, as always.
