What does this mean???
'Class ReefAngelClass'has no member named 'LoadWebBanner'
WiFi_LED_unit_installed_main_sketch_4_temp.ccp: In function 'void setup()':
WiFi_LED_unit_installed_main_sketch_4_temp.68: error: 'class ReffAngelClass' has no member named 'LoadWebBanner
WiFi_LED_unit_installed_main_sketch_4_temp.ccp:In function 'void loop()':
WiFi_LED_unit_installed_main_sketch_4_temp.101: error: 'class ReffAngelClass' has no member named 'LoadWebBanner
This occur when I tried to downgrade to back to ver 14. I was unable to get ver 16 to talk to the client and I was having other issues with controling the PWMSLOPE so I try to down grade until I could give 16 all the time I needed. This error has occured on the sketch that I have been using for months without issue.
any ideas anyone
divingdon
- Contact:
Re: ReefAngelClass'has no member named 'LoadWebBanner'
That error means you are trying to use the WebBanner functions without enabling WIFI in your features file.divingdon wrote:What does this mean???
any ideas anyone
Either open up ReefAngel_Features.h and add this line:
#define wificurt
divingdon
Thanks Curt.
I thought I had WiFi define in the sketch but I had it commented out and I did need to change features file and comment out a few thing to free up some memory.
Don
Don
- Contact:
You may want to look into enabling SIMPLE_MENU to free up more space. It's only in .15 and later but it does help with the reduction of code size. Of course you will want to use the Client Suite to change all the memory values (if you ever needed to).divingdon wrote:Thanks Curt.
Don
divingdon
I will have to check that out. I haven't really been following the updates for awhile and i need to get back up to speed.
Thanks for the tip
Don
Thanks for the tip
Don
