Avastmarine ATO compatibility
Posted: Fri Nov 23, 2012 6:05 am
by Dugong
Im planning to use RA controller in 220v country and I'm also looking to buy avast marine ato kit listed here:
http://www.avastmarine.com/ssc/do/produ ... op-off-Kit
Which stated 110v input power. Of course I'm planning to get the one for RA digital output. Will it be compatible? Thanks for your help.
Re: Avastmarine ATO compatibility
Posted: Fri Nov 23, 2012 6:22 am
I think you are getting confused. They have 2 versions of the same product. One is a self-contained ATO system and one is a digital output to be interfaced with controllers.
Please contact them to see which one is best for you.
If you go with the digital interface to connect with RA, it will work just fine.
I have one of those and it works awesome!!
Posted: Fri Nov 23, 2012 6:46 am
by dbmet
I have one of the digital interface to connect with RA and it works great as well..
d
Posted: Fri Nov 23, 2012 9:05 am
by Dugong
Cool! Can't wait to install both of them. I'm tired topping off manually :x :D
