Can't get my RA's LEDs to work or connect to Client 3.0
Posted: Mon Dec 03, 2012 1:39 am
I have a Gen 1 unit for my freshwater plantedtank and never gotten it to work with the RAGEN and resorted to using the Lights on and Light off everyday so I went back to the preloaded code (but the preload code doesn't work with my display and the contrast is wayyy high although all the other features still worked)
Today I saw that Wizard was out so I figure id give custom codes another try
USB COM 5
-I began by uploading InitialInternalMemory
-Then I use Wizard to set my LIGHTS as Port 1
-Configured it to turn on at 5PM and off at 12AM
-Set my Daylight Dimming Channel as Slope
-Start Time =17:00
-Start %= 10%
-Duration = 30 minutes
-End Time = 00:00
-End Percentage = 50% ( anythign higher than 50% causing too much algae of my plants)
After the code was successfully uploaded the current time was 7PM and the lights weren't on
I checked the LED Dimming in the RA menu and it set to 20%? so I corrected the time and dimming percentage but i still dont get anything. The only time I can get the lights to turn on is if i go the Lights menu and set it to LIGHTS ON. It never shuts off until i set it to Lights off.
I installed Client Suite 3.0 but cannot get it to read the current status, when I try to refresh it gives me a memory error even though the listener is connected /running. I cannot stop the service so i uninstalled. Opened Reef Angel Controller and went to Serial Monitor and get nothing at all. I tried this on both Windows 7 and Windows 8 notebooks and none of them worked
USB COM 5
-Start Time =17:00
-Start %= 10%
-End Time = 00:00
