Multiple RA's in one house
Posted: Mon Dec 03, 2012 5:44 pm
by rossbryant1956
I have a friend that has four 300 gallon tanks in his house and I'd like to get them all on Reef Angel. Two of them are close enough to share a unit but the other two are not. How would I configure the wifi unit(s) to be able to monitor those RA units separately? Each wifi would grab their own IP, but would I use different ports for each so I get each tank out on the portal? Thanks in advance.
Re: Multiple RA's in one house
Posted: Tue Dec 04, 2012 8:17 pm
Yes, different ports.
Posted: Thu Dec 06, 2012 11:31 am
by wolfador
Just to add a bit more information incase any one else is wondering how. This would be configured in your "router"
RA1 <-Internal IP:port-> 192.168.1.10:9000 <-External IP:Port-> 68.125.120.72:9000 (example ip's)
RA2 <-Internal IP:port-> 192.168.1.11:9000 <-External IP:Port-> 68.125.120.72:9001
RA3 <-Internal IP:port-> 192.168.1.12:9000 <-External IP:Port-> 68.125.120.72:9002
You could also mess with the wifi settings to change the default port but I would just leave it standard and configure it in your firewall/router.
Posted: Thu Dec 06, 2012 1:54 pm
wolfador wrote:You could also mess with the wifi settings to change the default port but I would just leave it standard and configure it in your firewall/router.
+1 That would be my recommendation as well.
Posted: Thu Dec 06, 2012 2:45 pm
by rossbryant1956
So you are saying leave the RA wifi settings standard (port 2000 or whatever) and then map outside IP's individual incoming port(s) to a particular ip address and standardly assigned port on the inside? Thx
Posted: Thu Dec 06, 2012 3:01 pm
Yeah, and you should be able to point your phone app to the external ip/dns and it should work inside your net or out.
Posted: Fri Dec 07, 2012 5:28 pm
That's what I do on my home network with my 2 test units.
Posted: Tue May 03, 2016 11:55 pm
by dapg8gt
Longshot but by chance does anyone know how I would accomplish this on A XFINITY Cisco DPC3941T Gateway? Still early in my exploring the new unit I'm calling it a night now but thought I'd let this soak for a bit before I stress out some more tomorrow night =)..
Daniel
