Re: Very much problems with rawizard & rastatus
Posted: Fri Dec 14, 2012 10:22 am
Are you able to load any code the controller?
It looks like you got the wrong com port.
Posted: Fri Dec 14, 2012 12:26 pm
Ra status only works with wifi. It doesn't work with serial.
Did you try using the portal?
Sent from my Galaxy S3 using Tapatalk 2
Posted: Fri Dec 14, 2012 5:32 pm
Which one?
Posted: Sat Dec 15, 2012 5:48 am
Did you load the sample code to initialize all the memory variables. I forget the name of the sketch, but if you missed this step, you could have problems.
Posted: Sat Dec 15, 2012 9:46 am
