I installed version 3.0 Everything seems to be working fine except
When I click on the memory tab and hit refresh it comes back with the message
Can't retrieve memory settings please refer to error log.
Here is a print out from the error log. Is this a known bug?
*****12/14/2012 11:46:14 AM*****
Message:
Index was outside the bounds of the array.
StackTrace:
at ReefAngelWCFListener.ReefAngelListener.GetAllMemoryValuesPost10(String[] locations)
Message:
Value cannot be null.
Parameter name: String
StackTrace:
reefangel client 3.0 can't get memory settings
ldangelo
dmolton
Re: reefangel client 3.0 can't get memory settings
It's a known issue - have a look a few posts down on this thread for a solution. I need to update the application
http://forum.reefangel.com/viewtopic.ph ... 3&start=10
ldangelo
