Wifi problem
Wifi problem
I had a power outage and my wifi stopped working. Slow green light flashing on module. I tried using the wifi setup tool again it goes through the whole thing but stay on the auto port forwarding when originally automatically configured the port forwarding. How can I get this thing working again?
Re: Wifi problem
If the light is flashing slow green the Wifi module should be connected to your access point. Sounds like your Router\Access point's DHCP server may have assigned a new IP address to your WiFi module.
Can you ping the WiFi module?
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Wifi problem
open command promp and type
ping xxx.xxx.xxx.xxx
where xxx.xxx.xxx.xxx is your internal ip address
http://en.wikipedia.org/wiki/Ping_(networking_utility)
Re: Wifi problem
ok I did the ping. says 4 packets sent 4 recieved no loss on my internal ip addy. I assume this is good. What do I need to do next?
Re: Wifi problem
You should be able to connect to it by using the internal ip address, correct?
Re: Wifi problem
I can connect on iphone with the ip addy from the wifi setup utility only at home. The ip addy in the wifi utility is diffrent from my internal ip addy.
Re: Wifi problem
Ok, so you need to setup port forwarding on your router.
Check this site:
http://www.simpleportforwarding.com/
Check this site:
Re: Wifi problem
I tried the port forwarding not sure what I am doing!! What port to what port am I forwarding and what ip addy am I supposed to use?
Re: Wifi problem
I cannot figure this out!! Simple port forwarding asks for what port to what port to forward too, it also asks for what IP address to forward too. I don't know what values to enter?
Re: Wifi problem
Linksys wrt160n ver 3. Why won't it automatically set up port forwarding like it did in the past?
Re: Wifi problem
No Clue.. But I would check in the router settings to see what ip address the ReefAngel Wifi module has first.. Then you can forward port 2000 to that ip address.. I like to do everything manual in the router.
Maybe this site will help
http://portforward.com/english/routers/ ... ckland.htm
Re: Wifi problem
I finally got it working again!! After a week of trying. I never was able to figure out the manual port forwarding. I got frustrated and reset the router and went through the wifi setup wizard and it worked. The router set up the port forwarding without me having to do anything.
