Wifi problem
Posted: Tue Dec 25, 2012 6:56 pm
by creed
I had a power outage and my wifi stopped working. Slow green light flashing on module. I tried using the wifi setup tool again it goes through the whole thing but stay on the auto port forwarding when originally automatically configured the port forwarding. How can I get this thing working again?
Re: Wifi problem
Posted: Tue Dec 25, 2012 7:54 pm
by 00Warpig00
If the light is flashing slow green the Wifi module should be connected to your access point. Sounds like your Router\Access point's DHCP server may have assigned a new IP address to your WiFi module.
Can you ping the WiFi module?
Nick
Re: Wifi problem
Posted: Wed Dec 26, 2012 7:11 am
by creed
How do I ping the wifi?
Re: Wifi problem
Posted: Wed Dec 26, 2012 10:03 am
open command promp and type
ping xxx.xxx.xxx.xxx
where xxx.xxx.xxx.xxx is your internal ip address
http://en.wikipedia.org/wiki/Ping_(networking_utility)
Re: Wifi problem
Posted: Wed Dec 26, 2012 3:19 pm
by creed
ok I did the ping. says 4 packets sent 4 recieved no loss on my internal ip addy. I assume this is good. What do I need to do next?
Re: Wifi problem
Posted: Wed Dec 26, 2012 3:24 pm
You should be able to connect to it by using the internal ip address, correct?
Re: Wifi problem
Posted: Wed Dec 26, 2012 3:27 pm
by creed
I can connect on iphone with the ip addy from the wifi setup utility only at home. The ip addy in the wifi utility is diffrent from my internal ip addy.
Re: Wifi problem
Posted: Wed Dec 26, 2012 3:34 pm
Ok, so you need to setup port forwarding on your router.
Check this site:
http://www.simpleportforwarding.com/
Re: Wifi problem
Posted: Wed Dec 26, 2012 6:02 pm
by creed
I tried the port forwarding not sure what I am doing!! What port to what port am I forwarding and what ip addy am I supposed to use?
Re: Wifi problem
Posted: Wed Dec 26, 2012 6:10 pm
by dbmet
Your forwarding port 2000 to whatever ip address the reefangel wifi module has..
Re: Wifi problem
Posted: Sat Dec 29, 2012 8:36 am
by creed
I cannot figure this out!! Simple port forwarding asks for what port to what port to forward too, it also asks for what IP address to forward too. I don't know what values to enter?
Wifi problem
Posted: Sat Dec 29, 2012 9:07 am
by dbmet
What kind of Wireless Router do you have?
Re: Wifi problem
Posted: Sat Dec 29, 2012 9:23 am
by creed
Linksys wrt160n ver 3. Why won't it automatically set up port forwarding like it did in the past?
Re: Wifi problem
Posted: Sat Dec 29, 2012 10:10 am
by dbmet
No Clue.. But I would check in the router settings to see what ip address the ReefAngel Wifi module has first.. Then you can forward port 2000 to that ip address.. I like to do everything manual in the router.
Maybe this site will help
http://portforward.com/english/routers/ ... ckland.htm
Re: Wifi problem
Posted: Sat Dec 29, 2012 1:01 pm
by creed
I finally got it working again!! After a week of trying. I never was able to figure out the manual port forwarding. I got frustrated and reset the router and went through the wifi setup wizard and it worked. The router set up the port forwarding without me having to do anything.
Re: Wifi problem
Posted: Sat Dec 29, 2012 1:15 pm
by dbmet
Great!!!
