Lightning on demand
Posted: Mon Dec 31, 2012 7:20 pm
Hi Guys , sorry I've search thru the forum for this above funtion and tried to insert the standard PWM extension codes into mine but still fail to load it . Can anyone help me with this.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.DelayedOn( Port3,180 );
ReefAngel.Wavemaker( Port5,30 );
ReefAngel.Wavemaker( Port6,60 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(5,30,22,0,10,45,240,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(5,30,22,0,10,45,240,10) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(5,30,22,0,10,45,240,10) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(5,30,22,0,10,40,240,10) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(9,0,22,0,10,60,240,10) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(9,0,21,30,10,25,240,10) );
ReefAngel.Portal( "Dracula" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
