Ethernet with Arduino board
Posted: Wed Jan 02, 2013 11:21 am
Ok I have an open port on 80 and my IP is set. But I can not get the portal to find my ethernet board? "Unreachable" Do I have to use 2000?
https://forum.reefangel.com/
<RA><T1>804</T1><T2>698</T2><T3>773</T3><PH>862</PH><R>248</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>84/PWM><PWM>76<PWMD</RA
if (millis()-lastmillisin>2000)
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0x90, 0xA2, 0xDA, 0x0D, 0x28, 0x0E };
IPAddress ip(192,168,1,200);
IPAddress remoteserver(69,198,171,165); // forum.reefangel.com
EthernetClient clientout;
unsigned long lastmillisout=millis();
unsigned long lastmillisin=millis();
boolean sending=false;
char strout[400];
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(2000);
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(57600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac);
server.begin();
Serial.println(Ethernet.localIP());
void loop() {
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
// Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
while (client.available()) {
char c = client.read();
if (sending==false) Serial.write(c);
while (Serial.available()){
char c = Serial.read();
client.print(c);
if (millis()-lastmillisin>4000)
Serial.println("Timeout incoming");
Serial.flush();
client.stop();
Serial.flush();
client.stop();
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
// Serial.println("client disonnected");
if (Serial.available())
memset(strout,0,sizeof(strout));
int b=Serial.readBytesUntil('\n',strout,sizeof(strout));
Serial.flush();
// Serial.println(b);
Serial.println("Connecting");
if (b>10)
sending=true;
Serial.print(strout);
Serial.println(" HTTP/1.0");
Serial.println();
if (clientout.connect(remoteserver, 2000))
Serial.println("Connected");
// while (Serial.available()){
// char c = Serial.read();
// clientout.print(c);
clientout.print(strout);
clientout.println(" HTTP/1.0");
clientout.println();
while (clientout.available()) {
char c = clientout.read();
Serial.print(c);
if (millis()-lastmillisout>8000)
Serial.println("Timeout connected");
clientout.stop();
sending=false;
if (!clientout.connected())
clientout.stop();
sending=false;
Serial.println("Timeout global");
clientout.stop();
sending=false;
//GET /status/submitp.aspx?t1=806&t2=0&t3=0&ph=441&id=test&em=0&rem=0&key=&atohigh=0&atolow=0&r=0&ron=0&roff=255 HTTP/1.0
//GET /status/submitp.asp?t1=806&t2=0&t3=0&ph=441&id=test&em=0&rem=0&key=&atohigh=0&atolow=0&r=0&ron=0&roff=255 HTTP/1.0
//Host: forum.reefangel.com
//Connection: Keep-Alive
Serial.end();
Serial.begin(19200);
