Code not generating changes !
cjrudy
I am using the Wizard to generate code, it successfully uploads the code, the controller reboots but the changes are not there. The ports that are on/off never change from the pre-loaded settings. I have tried using the code option as well as the internal memory option. Any ideas ?
Re: Code not generating changes !
Can you try uploading the ControllerTester code?
File->Sketchbook->Example Codes->ControllerTester
cjrudy
I uploaded that code, which definitely worked. I tried to upload custom code again which worked but I found the problem. For some reason the only ports that work right are the "Always On" ports, any ports with certain parameters like ATO, Heater or Lights dont seem to program correctly. For example , heater ports show off even though they are programmed to be on.
dbmet
- lnevo
cjrudy
Yes, date and time are correct, here is my code
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.StandardATO( Port8 );
ReefAngel.Portal( "cjrudy" );
- lnevo
The code is using memory settings for your devices. Check all your times and temp settings in the portal under internal memory
cjrudy
Ok, well maybe I am not understanding this, the code is uploaded, the portal internal memory stettings match but the ports on the controller and the portal are different and neither is actually what I programmed
cjrudy
As programmed 1&2 are lights, 3&4 are heaters, 5-7 are always on and 8 is ATO which should be on
Would it be possible to upload a code with hard coded settings to begin and move to internal memory once you get things figured out and you know that the controller and the portal all all working and communicating correctly?
Those ports on your Portal indicate that you overrode several of the ports. Off and On are overrides. The Auto is when the controller is able to control them. If you override the port to on, it will always stay on, no matter what the controller is supposed to do with that port.
cjrudy
Ok, good to know about the On and Off overrides, I uploaded a code with hard coded settings and I thinks its working, all the ports show auto. My only issue now is working with a separate ATO switch. When I first set up the controller I plugged my ATO switch into port 1 and it would timeout after 60 seconds. Now that I programmed all the ports, I set the ATO on port 8 but its not on because I am using my own ATO switch.
So is there any simple way to set up a timer on any port ?
You have your own ATO system or your own float switch?
I'm not quite understanding your question.
cjrudy
My own system, switches , pump etc.
When I first got the RA, I plugged my ATO pump into Port 1 which was always on but would only run for 60 seconds max. Now I have programmed all the ports and Port8 is now the ATO but it always shows off, not sure why.
I am new at this so maybe i am not fully understanding everything.
You probably just need to set port 8 to be always on, if you have your own system.
cjrudy
Thats how i have it set now, looking to have a timer function on the ATO as a fail safe, any way to set that up on a specific port?
Not with your own system.
RA needs to know when to start the timer and with your own system, it would never know.
- lnevo
Your code is setting the port to an ato port...if you wanted ra to backup, you would need your float switches setup and plugged in. It will turn the port on only when atolow is active and off when ato high is active or your timeout..at least thats how your code above is written. Otherwise just make it an always on port.
cjrudy
Got it, thanks for everyone's help.
I am just using an "AutoTopOff.com" float switch setup, maybe I can just wire the two float switches I am currently using into the RA Connectors.
- lnevo
No reason it wouldn't. Thats the way i would go
at least then you can monitor and alert on your float switch statuses etc.
