ReefAngel AddCustomColor question
Posted: Sat Jan 05, 2013 6:32 pm
by psyrob
It's been a while since I updated my libraries, just uploaded 1.0.2...and in the change log I saw that custom colors is re-enabled? where in your code do you add ReefAngel.AddCustomColors()? Or is just automatic when I upload the new libraries?
Re: ReefAngel AddCustomColor question
Posted: Sat Jan 05, 2013 7:36 pm
by psyrob
The reason I ask this is I uploaded the new libraries, but I can't get my outletcirclebox to display on the screen with the colors I set for outlet on and off in CustomColors....it stays on the default colors even tho I changed them in the custom colors
Posted: Sat Jan 05, 2013 8:02 pm
You should be able to add the ReefAngel.AddCustomColors() in the setup() function and it will get included. The same goes for the AddWifi (or whatever it is called).
Posted: Sat Jan 05, 2013 9:18 pm
by psyrob
Thanks Curt...that did the trick...
