Tunze Control
Posted: Mon Jan 07, 2013 1:25 pm
by discocarp
I have a pair of Tunze Stream 6105's. I will likely do something more complex later, but this is what I put together for now. I found rimai's tunze pulsing functions but I wanted a little more, so I wrote a quick sine wave function to control them. Basically it does this:
Then I added on the pulsing code to pulse from the minimum up to the sine wave flow.
//*** Define only one mode ***
//#define TUNZE_MODE_SINE // sine wave, no pulse
//#define TUNZE_MODE_LONG // no sine wave, long pulse
//#define TUNZE_MODE_SHORT // no sine wave, short pulse
//#define TUNZE_MODE_LONGSINE // sine wave, long pulse
#define TUNZE_MODE_SHORTSINE // sine wave, short pulse
#define TUNZE_MIN 30
#define TUNZE_MAX 75
#define TUNZE_SINE_SEC 23400
#define TUNZE_SINE_SYNC false
#define TUNZE_LONGPULSE_SEC 2
#define TUNZE_LONGPULSE_SYNC true
#define TUNZE_SHORTPULSE_MS 500
#define TUNZE_SHORTPULSE_SYNC true
//PulseMinSpeed - % for minimal speed
//PulseMaxSpeed - % for maximum speed
//PulseDuration - Duration (milliseconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
//PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
byte TunzeShortPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,30,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
  tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
    return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
//PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
byte TunzeLongPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
byte TunzeSineWave(boolean isleftpump, byte minspeed, byte maxspeed, int period_sec) {
  double x,y;
  x=double(now()%(period_sec));
  x/=period_sec;
  x*=2.0*PI;
  if (!isleftpump) x+=PI; // shift the sine wave for the right pump
  y=sin(x);// y is now between -1 and 1
  y+=1.0; // y is now between 0 and 2
  y/=2.0; // y is now between 0 and 1
  // now compute the tunze speed
  y*=double(maxspeed-minspeed);
  y+=double(minspeed);
  y+=0.5; // for proper rounding
  // y is now between minspeed and maxspeed, constrain for safety
  return constrain(byte(y),30,100);
void RunTunzes() {
#ifdef TUNZE_MODE_SINE
    ReefAngel.PWM.SetDaylight(TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC)); // left tunze
    ReefAngel.PWM.SetActinic(TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC)); // right tunze
#endif
#ifdef TUNZE_MODE_LONG
    ReefAngel.PWM.SetDaylight(TunzeLongPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_LONGPULSE_SEC,true)); // left tunze
    ReefAngel.PWM.SetActinic(TunzeLongPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_LONGPULSE_SEC,TUNZE_LONGPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_SHORT
    ReefAngel.PWM.SetDaylight(TunzeShortPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_SHORTPULSE_MS,true)); // left tunze
    ReefAngel.PWM.SetActinic(TunzeShortPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_SHORTPULSE_MS,TUNZE_SHORTPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_LONGSINE
    ReefAngel.PWM.SetDaylight(TunzeLongPulse(TUNZE_MIN,TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_LONGPULSE_SEC,true)); // left tunze
    ReefAngel.PWM.SetActinic(TunzeLongPulse(TUNZE_MIN,TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_LONGPULSE_SEC,TUNZE_LONGPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_SHORTSINE
    ReefAngel.PWM.SetDaylight(TunzeShortPulse(TUNZE_MIN,TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_SHORTPULSE_MS,true)); // left tunze
    ReefAngel.PWM.SetActinic(TunzeShortPulse(TUNZE_MIN,TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_SHORTPULSE_MS,TUNZE_SHORTPULSE_SYNC)); // right tunze
#endif
I just set up the #defines and call RunTunzes from in the loop.
Re: Tunze Control
Posted: Mon Jan 07, 2013 1:34 pm
Nice :)
Re: Tunze Control
Posted: Mon Jan 07, 2013 1:46 pm
by discocarp
The Reef Angel officially earned its cabinet space, as I pulled out the tunze 7095 controller. :)
Re: Tunze Control
Posted: Mon Feb 11, 2013 10:10 am
by mason dixon
Discocarp, how are you liking this code so far? I have 2 6095's that I'd like to control with this same code, I'm still green to putting code together with my RA, can you put it in the right places for me? Thanks
Here's my code so far:
    ReefAngel.FeedingModePorts = Port7Bit;
    ReefAngel.WaterChangePorts = Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port6Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 790 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,9,0,20,0 );
    ReefAngel.StandardLights( Port2,9,0,20,0 );
    ReefAngel.StandardLights( Port3,8,0,23,0 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(6,0,23,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 5, PWMSlope(20,0,10,0,15,70,20,15) );
    ReefAngel.Portal( "Mason Dixon" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,76, "PHE:" );
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,76, ReefAngel.Params.PHExp );
    // Main Relay Box
    // Date and Time
Re: Tunze Control
Posted: Sun Mar 10, 2013 8:17 pm
by carlii
So how woudl I add this function to my Reef Angel? I have a pair of Tunze 6055s.
Re: Tunze Control
Posted: Sun Mar 10, 2013 8:48 pm
Which one do you want to use?
Re: Tunze Control
Posted: Sun Mar 10, 2013 9:25 pm
by carlii
I guess my challenge is translating the code above to work on ports 0 and 1 on the analogue dimming expansion. I don't know how to program my RA + unit to see the expansion or use it.
Re: Tunze Control
Posted: Mon Mar 11, 2013 8:55 am
There are basically 5 waveforms that discocarp created.
Which mode do you want to run?
Re: Tunze Control
Posted: Thu Mar 14, 2013 1:36 pm
by jayclaire
I'd like to try TUNZE_MODE_SINE // sine wave, no pulse
Re: Tunze Control
Posted: Thu Mar 14, 2013 2:11 pm
Ok, what you do is copy the whole thing posted in that post and paste it at the end of your code after the last }
Change the code you pasted to whichever function you want to use.
Please note that only one mode should be uncommented.
//#define TUNZE_MODE_SHORTSINE // sine wave, short pulse
Then, in your loop section, add this:
RunTunzes();
Re: Tunze Control
Posted: Mon Mar 18, 2013 9:18 am
by carlii
OK I copied and pasted the code, but get an error:
a function defintion is not allowed here before '{' token
Here is my code.
ReefAngel.FeedingModePorts = Port1Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit |Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit ;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port5Bit | Port7Bit | Port8Bit;
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( highATOPin );
ReefAngel.Relay.On( Box1_Port8 ); //Return Pump
ReefAngel.Relay.On( Box1_Port6 ); //BioPellet Reactor
byte tspeed=0;
if (PulseSync)
return tspeed;
byte tspeed=0;
if (PulseSync)
return tspeed;
double x,y;
x/=period_sec;
x*=2.0*PI;
void RunTunzes() {
#endif
#endif
#endif
#endif
#endif
ReefAngel.WaterLevelATO(Port1,1800,45,55);
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.StandardFan( Port8 );
ReefAngel.DosingPumpRepeat1( Box1_Port1 );
ReefAngel.DosingPumpRepeat2( Box1_Port2 );
ReefAngel.StandardFan( Box1_Port4 );
ReefAngel.StandardLights( Box1_Port3,20,0,6,0);
ReefAngel.StandardHeater( Box1_Port7 );
ReefAngel.StandardHeater( Box1_Port5 );
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.AI.ChannelWhiteSlope();
ReefAngel.AI.ChannelBlueSlope();
ReefAngel.AI.ChannelRoyalBlueSlope();
RunTunzes();
///skimmer float switch
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.On(Port7); else ReefAngel.Relay.Off(Port7);
// moonlight function // 6p to 8p
if ( (hour() >= 18) && (hour() < 20) ) ReefAngel.Relay.On( Port3 );
//lighting fonction with night mode
if ( (hour() >= 18) || (hour() < 10) ) // from 7p - 10a
ReefAngel.AI.SetChannel(White,0);
ReefAngel.AI.SetChannel(Blue,0);
ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*.06);
// during the day
if ( (hour() >= 10) || (hour() <= 18) ) // from 10a - 6p
ReefAngel.Portal("carlii", "*********");
byte x,y;
ReefAngel.LCD.Clear(BtnActiveColor,5,0,127,11);
ReefAngel.LCD.DrawText(DefaultBGColor,BtnActiveColor,30,3,"My Reef Angel");
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 15, ReefAngel.Params);
ReefAngel.LCD.Clear(DefaultFGColor,5,52,127,52);
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,15,55,"Aqua Illumination");
x=15;
y=68;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"White:");
ConvertNumToString(text, ReefAngel.AI.GetChannel(White), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+74,y,text);
y+=10;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Blue:");
ConvertNumToString(text, ReefAngel.AI.GetChannel(Blue), 1);
strcat(text," ");
y+=10;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Royal Blue:");
ConvertNumToString(text, ReefAngel.AI.GetChannel(RoyalBlue), 1);
strcat(text," ");
y+=10;
ReefAngel.LCD.DrawOutletBox(12, 97, TempRelay);
ReefAngel.LCD.DrawOutletBox(12, 109, TempRelay);
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,36, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,36, ReefAngel.WaterLevel.GetLevel() );
Re: Tunze Control
Posted: Mon Mar 18, 2013 9:38 am
Almost...
The pasted piece had to be all the way at the end of your code.
    RunTunzes();
    // during the day
byte x,y;
  ReefAngel.LCD.DrawMonitor(15, 15, ReefAngel.Params,
  x=15;
  y=68;
  strcat(text," ");
  y+=10;
  strcat(text," ");
  y+=10;
  strcat(text," ");
  y+=10;
  // Water Level
  byte tspeed=0;
  if (PulseSync)
    return tspeed;
  byte tspeed=0;
  if (PulseSync)
    return tspeed;
  double x,y;
  x/=period_sec;
  x*=2.0*PI;
void RunTunzes() {
#endif
#endif
#endif
#endif
#endif
Re: Tunze Control
Posted: Mon Mar 18, 2013 10:13 am
by carlii
Thanks, it compiles now. So how do I assign this function to the Tunzes I have on my dimming expansion?
Re: Tunze Control
Posted: Mon Mar 18, 2013 10:21 am
You can add the channels to each function inside the RunTunzes() function
Like this:
ReefAngel.PWM.SetChannel(0,TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC));
Re: Tunze Control
Posted: Thu Mar 21, 2013 6:12 am
by carlii
Works great! thanks.
Re: Tunze Control
Posted: Fri Mar 29, 2013 8:24 am
by Paulturner911
Is this the strength of the flow in percentage?
Can you more than one mode at random to a channel?
