Serial Connection
Posted: Tue Jan 08, 2013 5:44 pm
by cjrudy
Trying to connect to the Wifi attachment in order to downgrade the firmware. Having trouble with the serial connection. I have tried both teraterm and Putty and multiple COM ports with no luck, settings are correct, the green light lights but no blue. The session appears to start, but then nothing happens , no start up screen, no where to get into cmd mode.
The Wifi works, but occasionally drops the connection
Any ideas?
Serial Connection
Posted: Tue Jan 08, 2013 5:46 pm
by dbmet
What baud rate are you using?
Serial Connection
Posted: Tue Jan 08, 2013 5:47 pm
by dbmet
After connecting are you entering
Then you will get a command prompt
Re: Serial Connection
Posted: Tue Jan 08, 2013 5:58 pm
by cjrudy
Set it to 9600, all I get is blank screen, the manual says I should see some screen and then I would enter $$$ for cmd mode. I tried entering $$$ and got nothing
Posted: Tue Jan 08, 2013 6:00 pm
by DrewPalmer04
Try 56700?
Serial Connection
Posted: Tue Jan 08, 2013 6:08 pm
by dbmet
Yup it's 57600
Posted: Tue Jan 08, 2013 6:19 pm
by DrewPalmer04
Darn typo. Yes 57600
Posted: Tue Jan 08, 2013 6:44 pm
by cjrudy
Yep thanks, I first tried to upgrade to the beta but said it couldn't find it, so I down graded to 232.
hopefully no more disconnects
Posted: Tue Jan 08, 2013 7:33 pm
by dbmet
Good Luck.. I tried 2.36 and had disconnects.. Started over with factory settings. Then went to 2.32. Then ended up with the Beta and I added an external antenna.
