Everytime I go to upload I get
"Serial Port Com3 already in use" I even unplugged the USB restarted my computer and plugged it back in only after I opened Arduino 1.01.
Does running it through VMware cause this? I was able to upload through the Wizard fine.
Upload Issue
- DrewPalmer04
Re: Upload Issue
Are you using the client suite? You have to go to modify then stop the listener and the logger
jtomasi
Re: Upload Issue
Yes, that worked! Thanks you!
- DrewPalmer04
Re: Upload Issue
You're welcome!! FYI. Every time you restart the computer. It'll start again. Just do you know to stop them before upload.
