I am working on this touchscreen http://forum.reefangel.com/viewtopic.ph ... 2&start=30 and I was planning to try to use a button to have off/on override of the relay switches like you can do from the web/portal/phoneapps. I was thinking I would need a series of if/then statements in my main and a set of variables early in the code to override the relay status. However, I'm thinking there must be something in the libraries that lets you override the relay status since none of us code for it, but we can all do it from the accessory apps.
Is there an easy way to do this?
Jon
