My ReefAngel with my new 800L tank
Posted: Mon Aug 29, 2011 6:44 am
by Xender
Hello everybody,
I need your help to do my pde for my new tank ;-)
[youtube]http://www.youtube.com/watch?v=MfXhgFvWprk[/youtube]
Here is what I need :
Standard running
• Light 1 ON : 7h00 am --> 8h30 pm
• Light 2 ON : 8h00 am --> 11h00 pm
• Moonlight ON slowly % : 10h55 pm --> 7h00 am
• Heater :
o ON When TEMP <= 29°C
o OFF When TEMP >= 29.5°C
• Chiller : ON When TEMP >= 31.5°C (Overheat)
• CO2 :
o ON When PH >= 6.5
o OFF When PH <= 6
o OFF between 11h00 pm and 7h00 am and IF PH >= 6.5
• Bubbles :
o ON When PH <= 5.8
o ON between 11h00 pm and 7h00 am and IF PH <= 5.8
• Pump 1 ON
• Water Change mode ON one time every day at 1h00 pm
Menus
• Feeding
• Water Change force
• Top Off Force
• Cleaning pump
• Vacuum Cleaning
• Standard Lights
• Moonlights
• Version
Relay Box
1: Light 1
2: Light 2
3: Bubbles
4: Heater
5: CO2
6: RO Osmoseur
7: Drain Tank Pump
8: Pump 1
Actinic LED driver output : Moonlights LED 12V DC
Daylight LED driver output : Chiller 12V DC
Vacuum Relay?
Wifi log YES and Banner YES
Client suite will be the next step ;-)
TOPOFF Force.png (7.87 KiB) Viewed 9810 times
Thanks for your help
Re: My ReefAngel with my new 800L tank
Posted: Mon Aug 29, 2011 6:46 am
by Xender
Water Change.png (8.09 KiB) Viewed 9809 times
Vacuum Cleaner.png (7.1 KiB) Viewed 9809 times
Posted: Mon Aug 29, 2011 7:35 am
by binder
Some of the stuff you desire is simple to implement (ie, heater, chiller, lights, moonlights)
Some of the stuff will require a little additional coding inside the pde (ie, co2 related to ph, bubbles)
The menu will require more work with the libraries being updated/modified to suit your needs. I will take a look into this one a little more. Initially what I would suggest would be to enable SIMPLE_MENU and then tweak / modify the menu entries / labels as needed and update the appropriate functions they call.
Posted: Tue Aug 30, 2011 2:46 am
by Xender
CO2 function :
  // If the PH falls below 6.50 then turn off port5 which contains the CO2,
  // otherwise keep the port on
  if ( ReefAngel.Params.PH < 650 )
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.On(Port5);
Posted: Tue Aug 30, 2011 11:24 pm
by Xender
Please help :oops:
Posted: Wed Aug 31, 2011 5:04 am
by rwijbenga
I am also trying to get my Reefagel suited for a fresh water tank with CO2. So I hope somebody can help us out, because RAgen is not suited for freshwater tanks yet.... Hint hint... ;)
I am going to try to program the functions myself, but I am not an experienced programmer... :(
Posted: Wed Aug 31, 2011 8:31 am
by binder
i wont be able to help much until this weekend due to my work schedule. Plus due to the complexity of what you want to accomplish, it will take some time to figure it out and get it working properly.
Posted: Wed Aug 31, 2011 10:47 am
by Xender
ok thanks curt !
Posted: Wed Aug 31, 2011 12:33 pm
by rwijbenga
Super Curt !!
You would also make me very happy and a girlfriend of mine, she also has bought a RA on my advice.. :)
So already 3 users for this single PDE... :)
And the setup can easily be used by other freshwater tank users..
Of course also thanks to Xender for putting it into words...
Remco
Posted: Wed Aug 31, 2011 12:56 pm
Which relay the chiller connected?
Posted: Wed Aug 31, 2011 12:58 pm
My bad. I just saw you are using Daylight I/O port.
Do you have a SSR to turn the chiller on/off?
Posted: Wed Aug 31, 2011 1:19 pm
This should give you a start.
It does the standard running section described above
I'm also curious to see what Curt is gonna come up for the custom menu :o
Let me know if it works for you.
Features file:
#define DisplayLEDPWM
#define VersionMenu
#endif  // __REEFANGEL_FEATURES_H__
Code:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
    ReefAngel.Relay.On(Port8);
  // Specific functions
  ReefAngel.StandardLights(Port1);
  ReefAngel.MHLights(Port2);
  ReefAngel.StandardHeater(Port4);
//CO2
  if ( ReefAngel.Params.PH <= 600 )
  if ( ReefAngel.Params.PH >= 650 )
//Bubbles
  if ( ReefAngel.Params.PH <= 580 )
    ReefAngel.Relay.On(Port3);
  if ( ReefAngel.Params.PH >= 595 )
    ReefAngel.Relay.Off(Port3);
//Chiller
  if ( ReefAngel.Params.Temp1 >=315 )
    ReefAngel.PWM.SetDaylight(100);
  if ( ReefAngel.Params.Temp1 <=300 )
    ReefAngel.PWM.SetDaylight(0);
  if (hour()>23 || hour()<7)
    ReefAngel.PWM.SetActinic(PWMSlope(23,0,7,0,0,MoonPhase(),90,ReefAngel.PWM.GetActinicValue()));
byte MoonPhase()
  int m,d,y;
  int yy,mm;
  long K1,K2,K3,J,V;
  byte PWMvalue;
  m=month();
  d=day();
  y=year();
  yy=y-((12-m)/10);
  mm=m+9;
  if (mm>=12) mm-=12;
  K1=365.25*(yy+4712);
  K2=30.6*mm+.5;
  K3=int(int((yy/100)+49)*.75)-38;
  J=K1+K2+d+59-K3;
  V=(J-2451550.1)/0.29530588853;
  V-=int(V/100)*100;
  V=abs(V-50);
  PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
  //pinMode(lowATOPin,OUTPUT);
  return (PWMvalue*100)/255;
Posted: Wed Aug 31, 2011 8:00 pm
by binder
rimai wrote:I'm also curious to see what Curt is gonna come up for the custom menu :o
I have a few tricks up my sleeve for getting a custom menu. The recent push for it has sparked my thought process and I had a good brain storm session Sunday morning and my 4' tall x 6' wide dry erase board is covered with design ideas. :geek:
Posted: Wed Aug 31, 2011 11:50 pm
by Xender
rimai wrote:My bad. I just saw you are using Daylight I/O port.
What's "SSR" ?
I thought that I can connect directly my LED to the Daylight I/O port Witch I beleive that the controler can DIM from 0 to 12V right?
Here is the LED I bought : http://www.ampoule-leds.fr/neon-led-eta ... -2339.html
I didn't bought the tranformer 220V AC / 12V DC.
Thanks for the start of the pde I will let you know :D
Posted: Thu Sep 01, 2011 9:07 am
SSR=Solid State Relay.
Your original post had the chiller connected to the daylight PWM channel.
If you are going to use your LED system, where is the chiller connected?
By looking at the page you linked, the driver for the LED system is not dimmable, but I can't read French. You do need the driver though. The Reef Angel only outputs PWM signal that are used by the driver to dim the lights. You can't use that signal to power up the lights directly.
Posted: Thu Sep 01, 2011 10:03 pm
by Xender
I thought to use the Actinic LED driver output for led sorry.
Where do you by your LED?
I thought i can dim by voltage from 0 to 12V :-(
Maybe i will need to by new LED and PWM extention so.
Posted: Fri Sep 02, 2011 8:11 am
Oh, I don't sell LEDs.
The 0-10VDC that RA outputs is indeed for dimming purposes, but the LED driver must be dimmable to use the signal from RA.
The driver is the one that actually does the dimming. The RA just provides how much you would like the driver to dim by sending the 0-10VDC PWM signal.
Most people are using meanwell drivers, such as ELN-60-48P.
http://www.rapidled.com/servlet/the-26/ ... ble/Detail
I've seen some using Thomas Research, Recon and Buckpucks.
Be advised that buckpucks have a very strange configuration that does not isolate the output side to the dimming circuitry, which leads to a lot of noise that causes RA to crash. We had to create a special circuitry board to isolate the signal to make it work.
But even with the PWM expansion module, you will not be able to connect the LEDs directly to the outputs. You would still need the dimmable driver to power the LEDs.
Posted: Tue Oct 25, 2011 6:44 am
by Xender
I posted the video of my tank on the first post.
Thanks to Reef Angel Controler ;-)
Posted: Tue Oct 25, 2011 8:07 am
That's awesome!!
Posted: Sun Nov 06, 2011 7:42 am
Ok Xender, now that we have the ability of doing custom menus, where are you with your code?
Which of your customs modes is that you would like to work on first?
Can you post your latest code and features file?
