ReefAngel Status
ReefAngel Status
I've been working on a Status application that will be cross platform so everybody can use it. Currently, if you are not a windows user you cannot update the memory values on the controller unless you go through a web browser. This is a pain and tough to do at times.
Official Release: 1.1.1
New Features:
  • updated xml tags processed, this should fix any parsing errors from the controller
Current Functions:
  • wifi communications only (com still in the works)
  • memory location reading/writing
  • query the status of the controller and display the information.
  • XML parsing is also handled in the Memory tab
  • double click memory information in memory box and fills in location and memory type
  • get controller software version
  • get controller date & time
  • set controller date & time to match system date & time
  • controller IP and port are now saved in the settings
  • main relay status is now added - ability to toggle ports on/off
  • Added new 1.0 memory locations
Here are some future functions:
  • Communications via COM ports
Feedback is always welcomed. If you use a language other than English, I'm curious to know how well the localization works.
Side Note: If somebody has graphic skills and wants to design a better icon for this app, please PM me. You'll get your name listed in the credits. :)
Here's the link to download the file:
http://curtbinder.info/apps/status-1.1.1.jar
If you want an older version (for whatever reason), feel free to browse the files: http://curtbinder.info/apps
The status apps start with "status-".
The application is written in Java for a reason, ie Cross Platform (and also android runs Java ;-)) So you MUST have java installed on your computer, preferably 6 or later (exact version is unknown so please help me test if you can).
Usage:
  • Windows - save file and double click on it to run.
  • Mac - save file and launch it.
  • Linux - save file to computer. right-click on the file and change the permissions to allow Executing. then you can double-click to run. if that fails, open terminal and navigate to folder containing file. execute this command:
    java -classpath status-1.1.1.jar info.curtbinder.jStatus.Classes.StatusApp
Enjoy,
Re: ReefAngel Status
Cool!!!
Let me check it out
lukeluke
Post by lukeluke »
this applet works with the web authentication ?
Bye
lukeluke wrote:this applet works with the web authentication ?
Bye
No, it currently does not work with the web authentication. I have not added that in yet.
chase
Post by chase »
Ahh, nice....did some messing around and was able to read/write several values. Makes it nice since I don't have to upload a new pde every time I want to modify simple values, lcd timeout, feeding mode, lights, etc. and of course no USB hookup required!
lukeluke
Post by lukeluke »
great apps....
thanks curt ;-)
P.S. do you think is possible extend this apps for update the web banner and send the email allarm, like do the dave client ?
abhi_123
Post by abhi_123 »
for some reasons i am not able to extract exe file file from the zip folder. i am using window7 with java installed on my system already.
any idea how to extract & download the software?
Sebyte
Post by Sebyte »
I am also running Win7, and I always use WinRAR http://www.win-rar.com/website/index.php?id=start&L=0
I have just downloaded the zip file and I decompressed ok.
Dont know what else to suggest :?
abhi_123
Post by abhi_123 »
i also extract the files from the zip but not able to understand which file should i run to install the software on my system.
Sebyte
Post by Sebyte »
OK, lets look at the file properties. Right click on the file and see if you get this:-
Check at the bottom to see if you have the file Blocked for security protection. If so click to unblock.
That should work. :)
abhi_123 wrote:for some reasons i am not able to extract exe file file from the zip folder. i am using window7 with java installed on my system already.
There is not an EXE file in the JAR file. The JAR file is a java executable file. What you need to do is simply download the JAR file then you double click on it to run it. If you have java enabled on your computer it should automatically launch and run the app. You may have to "unblock" it like Sebyte said, but otherwise it should simply run without any other extraction or unzipping.
agentgreen
Post by agentgreen »
How do I specify what COM port to use in this app?
agentgreen wrote:How do I specify what COM port to use in this app?
Unfortunately COM ports are not working in this app. It's purely wifi only right now. I have had intentions of adding COM support but have not been successful in getting it to work across all platforms easily. I think I will have to revisit this issue.
agentgreen
Ah gotcha. My wifi module is out of commission right now which is why I asked.
Sent from my Transformer TF101 using Tapatalk 2
Bryan
Post by Bryan »
Hi Curt:
Any chance the COM port option will be supported.
-=Bryan=-
At least with windows :)
Well, the whole idea of Java is to be cross platform.
If you want just windows, you can use the Client :)
The problem is that there is no java implementation for serial communication.
You have to use a work around that is OS specific, which makes is not trully cross-platform.
So, if there is ever an update for serial, there would have to be 3 packages (Windows, MacOSX, Linux).
That's what I had to do with the wifi utility.
Bryan
Post by Bryan »
Problem with Client is it requires admin rights to install. Want to monitor the tank in my office. PC's are locked solid. Reef Angel Status will run without admin rights.
-=Bryan=-
Bryan wrote:Hi Curt:
Yes, I would like to get COM port option working at least for windows. Like Roberto said, there's no Java implementation for serial communication. I honestly have been focusing my time on the Android Status app and have not gotten back to the java app. I think I need to revisit it soon....after I get this release of the Android app out.
Bryan
Post by Bryan »
Thanks Curt that would be great, well at least for the windows users. :)
-=Bryan=-
Just released another version. Officially released v1.0.0 (too long in the works). Check out the original post for the updated information about what's new.
00Warpig00
Post by 00Warpig00 »
Nice. Working well here... thanks Curt
Nick
180G FOWLR
20GH QT#1
29G QT#2
00Warpig00 wrote:Nice. Working well here... thanks Curt
Nick
Good. I figured it was time I actually updated some of my apps to have all the features in them. :) This one will be slower than the Android one though but shouldn't be a problem.
daniella3d
Post by daniella3d »
wow, thanks so much!! that's exactly what I wanted and it work like a charm! :)
Plus it does not take much memory, so that's great. :D
daniella3d wrote:wow, thanks so much!! that's exactly what I wanted and it work like a charm! :)
Glad you like it. :)
tkeracer619
Post by tkeracer619 »
Awesome Job! Best one yet!
I think it exposed something in my Wifi module that I don't like.
It pops up every couple hours with a notification with Error 11 Bad URL. On the last version it would just kick back saying it couldn't connect and after a try or two it would work.
Last night I updated the firmware on my wifly and it seems to have made it much much better but I still get that error from time to time. Is there a way to turn that notification off or is something else going on that I need to address?
working great! is there an auto refresh set time? or do I have to do it manually?
DrewPalmer04 wrote:working great! is there an auto refresh set time? or do I have to do it manually?
right now it is manually updated...so you have to refresh yourself. i can look into doing the auto refresh feature but it would only be while the app was open. otherwise i would have to create a service and then log to a database and such (just like i do with the android app).
no, there is no way to turn off the notifications from being displayed. however i can work on adding that in if you would like. something like disable alerts or popup notifications. just let me know what you think and would like.
Cool ever thought about an icon so us Mac people could put it on our dock?
DrewPalmer04 wrote:Cool ever thought about an icon so us Mac people could put it on our dock?
yes. i started to look into it but never completed it. guess i need to revisit this as well. :)
