Delaying ATO port
Dugong
Delaying ATO port
Post by Dugong »
I'm using AvastMarine ATO kit to detect water level in my sump, currently this is the code:
ReefAngel.SingleATO( true,Port8,240,0 );
However when the tank restarted after lights off the pressure-sensitive switch seems to change state that turn on the port. So I am wondering how to delay the ATO port after the power turned back on? Thanks.
Re: Delaying ATO port
You can use this:
if (millis()>60000) ReefAngel.SingleATO( true,Port8,240,0 );
It will wait for 60 seconds before the ATO function starts working.
