New User, PH and SAL doesnt work!
Posted: Mon Feb 04, 2013 5:21 am
by kraken
Hi, I got the RA advanced with the wifi and SAL expansion kit, however, I couldnt get the ph and sal to work.
Please help, thanks
ReefAngel.UseFlexiblePhCalibration();,
ReefAngel.PHMin=550;// 550=PH7.0
ReefAngel.PHMax=830;// 830=PH10.0
ReefAngel.DayLights( Port1 );
ReefAngel.Portal( "kraken" );
int x,y;
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
Re: New User, PH and SAL doesnt work!
Posted: Mon Feb 04, 2013 9:35 am
Can you explain better what is happening?
Posted: Mon Feb 04, 2013 6:39 pm
by kraken
Never mind, silly me, I got the probes mixed up, now both working.
However, would you advice how to change the salinity value to relative gravity instead?
Also the salinity is being displayed as 350pt on the main controller display instead of 35pt.
Thanks.
Posted: Mon Feb 04, 2013 8:06 pm
You will need to come up with your own conversion table.
This is for reference: http://www.reefs.org/library/salinity.html
Just make sure it is temperature compensated too.
It changes as temperature goes up and down.
Posted: Tue Feb 05, 2013 12:53 am
by kraken
Grazie Roberto, will try to figure it out
