New Setup: Relay box making this clicking noise?
Posted: Sat Feb 09, 2013 9:46 pm
by langonej
I'm in the process of setting up a nano reef. Right now I just turned on my Reef Angel and following the Getting Started instructions.
I currently have:
ph probe
temp probe
heater (plugged into the designated heater outlet on the relay box)
return (plugged into the designated return outlet on the relay box)
From the handheld, it looks like the Reef Angel is constantly cycling to check the other outlets to see if anything has been plugged in.
That "checking" is making this constant clicking noise.
How do I stop this?
Re: New Setup: Relay box making this clicking noise?
Posted: Sat Feb 09, 2013 10:34 pm
That is the wavemaker ports.
Port 5 and port 6. Just click the joystick and change the wavemaker timers to zero if you don't want to use wavemakers.
Posted: Sun Feb 10, 2013 7:59 am
by langonej
Perfect! Thanks.
