I've followed the manual and connected the included temp probe to the middle connector.
The other end is in the tank.
I've rebooted the controller but all readings, t1, t2, and t3 all read," Error."
I'm sure I'm doing something something really stupid.
New Setup: t1, t2, t3 all read ERROR
Re: New Setup: t1, t2, t3 all read ERROR
Did you try a different port?
But if you tried rebooting already and it doesn't register, it could be that the probe may just not be working.
Try placing in different ports and rebooting after every change.
If it still does not work, send me a PM
Ceriff
- Contact:
Ok, same thing here, for the most part. T1 is good but T2 and T3 both show errors. I am only using the temp and PH probes at the moment and thought I disabled everything I wasn't using.
Seafoam Aquatics
Aquarium Maintenance
If you don't have T2 and T3, they will always show up as error.
If you don't want to see them at all, you can create your own custom main screen.
Ceriff
- Contact:
That's what I was leaning towards thinking. Thanks for the reply.
Seafoam Aquatics
