New Setup: t1, t2, t3 all read ERROR
Posted: Sun Feb 10, 2013 11:33 am
by langonej
I've followed the manual and connected the included temp probe to the middle connector.
The other end is in the tank.
I've rebooted the controller but all readings, t1, t2, and t3 all read," Error."
I'm sure I'm doing something something really stupid.
Re: New Setup: t1, t2, t3 all read ERROR
Posted: Sun Feb 10, 2013 11:49 am
Did you try a different port?
But if you tried rebooting already and it doesn't register, it could be that the probe may just not be working.
Try placing in different ports and rebooting after every change.
If it still does not work, send me a PM
Posted: Mon Mar 04, 2013 4:48 pm
by Ceriff
Ok, same thing here, for the most part. T1 is good but T2 and T3 both show errors. I am only using the temp and PH probes at the moment and thought I disabled everything I wasn't using.
Posted: Mon Mar 04, 2013 5:13 pm
If you don't have T2 and T3, they will always show up as error.
If you don't want to see them at all, you can create your own custom main screen.
Posted: Mon Mar 04, 2013 5:47 pm
by Ceriff
That's what I was leaning towards thinking. Thanks for the reply.
