ATO Float switch
jtomasi
ATO Float switch
Post by jtomasi »
I use the water level expansion - works great.
I would like to use the two float switches as follows:
Low Switch: Put in my ATO bucket to indicate if the bucket is low.
High Switch: Additional fail safe for the water level - put it in my sump to turn the ATO pump relay off if the sump gets to a certain level (this would also indicate if my return pump malfunctions for some reason as the water in the display will flow to the sump)
Where can I find the code for this?
Re: ATO Float switch
You can use something like this:
  ReefAngel.Relay.Off(Port1);
  ReefAngel.Relay.Off(Port8);
  ReefAngel.WaterLevelATO(Port1,60,70,75);
  ReefAngel.Relay.On(Port8);
